Just seeing if anyone is using the Turtkle board with Mbed5.x ? The example code is for mbed2.x and compiles and works fine. However my node code is in Mbed5.x.
I can compile and run mbed5.15 simple test code onto the turtle, but cannot get the USB serial port to work at all. Has anyone got the serial port talking to a PC under mbed5.x at all, and if so some assistance would be apprecaited.
@Heltec - Can you let me know what I/O pins are used for the USB connector please ?
Many thanks
