Hi, I am trying to send a packet through Serial monitor i.e. UART which is of length 366 character from one esp32(acting as trnasmitter) to another esp32(acting as receiver) . But at the receiver end i am only receiving a packet of lenth 110 characters. Any suggestions? Please find the code below:
Transmitter:
#include <ArduinoJson.h>
#include <ESP32_LoRaWAN.h>
#include “Arduino.h”
#define TX_OUTPUT_POWER 20 // dBm
#define LORA_BANDWIDTH                              0         // [0: 125 kHz,
//  1: 250 kHz,
//  2: 500 kHz,
//  3: Reserved]
#define LORA_SPREADING_FACTOR                       7         // [SF7…SF12]
#define LORA_CODINGRATE                             1         // [1: 4/5,
//  2: 4/6,
//  3: 4/7,
//  4: 4/8]
#define LORA_PREAMBLE_LENGTH                        1000         // Same for Tx and Rx
#define RX_TIMEOUT_VALUE                            1000
#define BUFFER_SIZE                                 1000// Define the payload size here
char txpacket[BUFFER_SIZE];
String receive_buffer;
void OnTxDone( void );
void OnTxTimeout( void );
typedef enum
STATUS_LOWPOWER,
STATUS_TX
}States_t;
int16_t txNumber;
States_t state;
bool sleepMode = false;
int16_t Rssi,rxSize;
uint32_t license[4] = {0x7233B70B, 0x0353AFAA, 0x90FDB660, 0x8F4B092C};
void setup()
while (!Serial);
SPI.begin(SCK,MISO,MOSI,SS);
Mcu.init(SS,RST_LoRa,DIO0,DIO1,license);
txNumber=0;
Rssi=0;
Radio.Init( &RadioEvents );
state=STATUS_TX;
if(Serial.available()>0)
receive_buffer = Serial.readString();
receive_buffer.toCharArray(txpacket,1000);
Serial.println("Arduino received following string: ");
Serial.println(receive_buffer);
switch(state)
case STATUS_TX:
txNumber++;
/sprintf(txpacket,"%s",“hello-COM3”);
sprintf(txpacket+strlen(txpacket),"%d",txNumber);
sprintf(txpacket+strlen(txpacket),"%s"," Rssi : “);
sprintf(txpacket+strlen(txpacket),”%d",Rssi);/
    Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
    state=STATUS_LOWPOWER;
case STATUS_LOWPOWER:
    LoRaWAN.sleep(CLASS_C,0);
//  Serial.print(“TX done…”);
state=STATUS_TX;
Radio.Sleep( );
//  Serial.print(“TX Timeout…”);
state=STATUS_TX;
Receiver:
#include <LoRa.h>
//  1: 250 kHz,
//  2: 500 kHz,
//  3: Reserved]
//  2: 4/6,
//  3: 4/7,
//  4: 4/8]
#define BUFFER_SIZE                                 500 // Define the payload size here
char rxpacket[BUFFER_SIZE];
typedef enum
STATUS_LOWPOWER,
STATUS_RX
}States_t;
int16_t txNumber;
States_t state;
uint32_t license[4] = {0x2354A73D, 0x73764032, 0x3E2BAA46, 0xC26155CE};
void setup()
while (!Serial);
txNumber=0;
Rssi=0;
state=STATUS_RX;
switch(state)
case STATUS_RX:
Serial.println(“into RX mode”);
Radio.Rx( 0 );
// int packetSize = LoRa.parsePacket();
Rssi=rssi;
rxSize=size;
memcpy(rxpacket, payload, rxSize );
rxpacket[size]=’\0’;
Radio.Sleep( );
Serial.printf("\r\nreceived packet “%s” with Rssi %d , length %d\r\n",rxpacket,Rssi,rxSize);
// Serial.println(“wait to send next packet”);
state=STATUS_RX;
Data I am trying to send:
{‘timestamp’: 2022-04-15 16:57:09’,‘sensors’: {‘id’: ‘CAMERA_ID’,‘type’: ‘Camera’,‘description’: ‘‘XYZ lab’’,‘location’: {‘lat’:39.25,‘lon’: -76.71,‘alt’: 48.15},‘networkdetails’:{‘status’: ‘up’},‘objects’: [{‘id’: ‘0’,‘description’:’+word[0]+’,‘type’: ‘static’,‘confidence’:’+word[x]+’,‘location’: {‘lat’: 0,‘lon’: 0,‘alt’: 0},‘videoPath’: ‘’,‘image’: ‘’}]}}
