Hello, I’m trying to send the data from a CCS811 sensor in my cubecell capsule. Testing CCS811 using the base code that comes in the arduinoasrmicro650x framework proves that my sensor works, now I want to send that data via LoRaWAN . The problem is, that CCS811 doesn’t work properly or doesn’t integrate well with the LoRaWAN code.
#include "LoRaWan_APP.h"
#include "Arduino.h"
#include <CCS811.h>
CCS811 ccs;
* RGB red means sending;
* RGB blue means RxWindow1;
* RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t appKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x66, 0x01 };
/* ABP para*/
uint8_t nwkSKey[] = {FILL};
uint8_t appSKey[] = {FILL};
uint32_t devAddr = (uint32_t)FILL;
/*OTAA or ABP*/
bool overTheAirActivation = false;
/*ADR enable*/
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
digitalWrite(GPIO0,LOW);
if(ccs.available()){
if(!ccs.readData()){
Serial.print("CO2: ");
Serial.print(ccs.geteCO2());
Serial.println(" ppm");
Serial.print("TVOC:");
Serial.print(ccs.getTVOC());
Serial.println(" ppb");
Serial.print("millis:");
Serial.println(millis());
else{
Serial.println("ERROR!");
digitalWrite(GPIO0,HIGH);
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
boardInitMcu();
pinMode(Vext,OUTPUT);
digitalWrite(Vext,LOW);
pinMode(GPIO0,OUTPUT);
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
if(!ccs.begin()){
Serial.println("Failed to start sensor! Please check your wiring.");
while(1);
// Wait for the sensor to be ready
while(!ccs.available());
switch( deviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
Note: I still didn’t code the data in order to send to the server because the problem is in this part:
else{
When it comes to the function ccs.readData() it works the first time, then it will always provide ERROR! Any idea why this occurs?
