Hi all…
I am new working with cubecell HTCC ab01. My work is to transmit Live temperature and humidity information from one cubecell HTCC ab01 to another cubecell HTCC ab01.
As of now i have completed to transmit “text” between two HTCC ab01 and also found live temperature and humidity data using DHT 22 sensor. But I am using separate Sketch code to Transmit/Receive “text” and found Temp and Humid data.
“”“But i need to combine the codes to Transmit/Receive Live temperature and humidity data between two cubecell HTCC ab01.”"""
Thanks in advance…
