TPL5010 Wireless Stick Lite
Hello Guys,
In order to assure the power consumption in deep sleep we have designed a PCB with TPL5010. Works perfect for lora, however for lorawan i’m having some issues.
First, for this application you need to know that I dont really care about downlinks, and the ADR could be also false.
The TPL5010 is responsible for cut the power from my board, in order to do that I need to simple put on IO on low and after in high.
However I’m not sure where should I use this function knowing that my board you be power off.
When I use in on this part of the code it just doesnt work, i think that can be related to the windows for downlink.
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass,debugLevel);
tpl_sleep();
I would like to know where is the best option to use it.
