Timed out waiting for packet header
Hello all,
unfortunately I have the problem that I can’t get any programming on a newly purchased Lora32 V2 board.
All the advice I have already read here is unfortunately not getting me anywhere, as there is no complete documentation on the subject. At least not here in the forum.
Every time I try to load a program I get the error message:
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
I have already tested the way described several times with RST and PRG button as well as bridging of pins. I have tested the whole thing on 3 different computers, with different hardware and different operating systems and also more than 10 USB cables.
It does not work. :expressionless:
Other ESP8266 modules and also Arduino UNO systems can be programmed without any problems.
I made a screenshot to show you that I have activated the boot mode, selected the correct board according to the documentation and I still try to upload only the Factory_Test_Wifi_LoRa32_V2.
Put the board into boot mode using the PRG button at startup
15:36:02.200 -> ets Jul 29 2019 12:21:46
15:36:02.200 ->
15:36:02.200 -> rst:0x1 (POWERON_RESET),boot:0x1 (DOWNLOAD_BOOT(UART0/UART1/SDIO_FEI_REO_V2))
15:36:02.200 -> waiting for download
Error message during upload
Der Sketch verwendet 668858 Bytes (51%) des Programmspeicherplatzes. Das Maximum sind 1310720 Bytes.
Globale Variablen verwenden 40688 Bytes (12%) des dynamischen Speichers, 286992 Bytes für lokale Variablen verbleiben. Das Maximum sind 327680 Bytes.
esptool.py v2.6
Serial port COM3
Connecting…………………____
Beim Hochladen des Sketches ist ein Fehler aufgetreten
Boardinformation
WiFi LoRa 32 (V2), Disabled, 240MHz (WiFi/BT, 921600, None, REGION_EU868, None on COM3
Driver
Does anyone have any ideas or have already been able to solve the problem?
Would be happy about constructive feedback.
