Hi, I can’t find an example of using the Vbat and Vsolar connectors. I am trying to use a typical solar panel and housing that can hold up to 6x18650. Do I need to use the charger PCB or can I connect the panel and bats directly to the T114?
T114 solar powered example
I think the max voltage to the charge controller is around 7v.
I use a 5.1v 5W panel meant to a charge security cam battery via USB.
