I am really stuck getting my V3 Lora OLED device working. There seems to be little if any support for it. All of the libraries I want to use (LMIC, TTN_ESP32…) are all specifically stated for the V2 boards.
TTN Support This for example is the best current resource on TTN and Heltec boards
I cannot see any way to get my board to talk to TTN or use LMIC.
This has been the case ever since these boards came out. When do you think Heltec will start supporting the V3 board as it has been months now?
I have tried modifying the example LoRaWAN code for the v3:
#include "LoRaWan_APP.h"
/* OTAA para*/
uint8_t devEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x05, 0xEE, 0x78 };
uint8_t appEui[] = { 0x22, 0x64, 0x1a, 0x8f, 0x67, 0xa7, 0x66, 0x35 };
uint8_t appKey[] = { 0xB8, 0xE9, 0x7B, 0xB7, 0x30, 0x2F, 0x08, 0x77, 0xDB, 0x34, 0x20, 0x84, 0x76, 0x71, 0x3C, 0xF9 };
/* ABP para*/
I set up the OTAA parameters in my TTN gateway and use AU915. I set the region in Arduino as AU915
The code compiles and downloads. My serial monitor says:
LoRaWAN AU915 Class A start!
+OTAA=1
+Class=A
+ADR=1
+IsTxConfirmed=1
+AppPort=2
+DutyCycle=15000
+ConfirmedNbTrials=4
+ChMask=0000000000000000000000FF
+DevEui=70B3D57ED005EE78(For OTAA Mode)
+AppEui=22641A8F67A76635(For OTAA Mode)
+AppKey=B8E97BB7302F0877DB34208476713CF9(For OTAA Mode)
TX on freq 916400000 Hz at DR 2
RX on freq 926900000 Hz at DR 10
RX on freq 923300000 Hz at DR 8
TX on freq 915400000 Hz at DR 5
RX on freq 923900000 Hz at DR 13
TX on freq 916000000 Hz at DR 2
RX on freq 925700000 Hz at DR 10
TX on freq 915800000 Hz at DR 5
RX on freq 925100000 Hz at DR 13
TX on freq 915600000 Hz at DR 2
RX on freq 924500000 Hz at DR 10
join failed, join again at 30s later
I see nothing on my gateway.
