Any suggestions to use for RTC and SD cards ?
I have previously used the below (when using adafruit featherwing arduinos) but since the pinout is different for the wifi lora 32 (V2) you can’t stack them (also have not yet tried importing the libraries and if they even work).
So any suggestions of what to use ? I would need both battery backed up RTC and a lot of data to be saved when device is not capable of sending.
