Sufucient IoT Hub Wifi not working
I received the IoT Hub last week and can get the ethernet to connect at boot time and the wifi once I have logged in as root using ‘bash wlan-connect.sh yourssid yourpwssd 1’ as documented. However, the persitent version does not work. The file in relevant the directory is created by the command wpa_passphrase SSID Password > /etc/wpa_supplicant/user_wifi.conf, but is not executed on bootup. The Debian documentation also states that it should work. It must have disabled it in the code.
Please advise on how I can make this work, as the device is supposed to operate without being connected to a computer.
Best
Wolfgang Daum
With the help of Heltec support I got the hub to work. The main thing was to flash the latest image and then follow the setup instructions. Thank Heltec support.
NOTE: the max micro SD card size is 32G.
W. Daum
