Startup from Deep sleep
im having an issue where if i put my cubecell into deep sleep via lowPowerHandler(); then on wake up my i2c sensor doesn’t seem to work, it is connected to Vext and ground scl sda,
any suggestions?
Thanks,
Ben
Your sensor must be initialised any time it is powered OFF and back ON again (Vext OFF/ON), so you must go through the complete initialisation sequence when you come out of deep sleep.
Fantastic that work great thanks for your help.
