Starting LoRa failed!
Hi guys, i have a Heltec ESP32 wifi Lora V3, my code is correct, but when i start the lora in the Heltec.begin(true, true, true, true, BAND);, in the OLED of LoRa is write “Starting LoRa failed!”, but when i try to replace the true of LoRa enable to LoRa disable, my code running normally
I’m Brazilian, so there are many words that you won’t understand
my code:
#include <Wire.h>
#include <heltec.h>
#include <WiFi.h>
#define BAND 915
int contador = 0;
const char* ssid = “Stark_wifi”;
const char* password = “35475024”;
Serial.begin(115200, SERIAL_8N1, 3, 1);
delay(2000); // Adicione um atraso para permitir a conexão Serial
Serial.println(“Iniciando…”);
// Conectar à rede Wi-Fi
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
Serial.println("Conectando ao WiFi...");
Serial.println(“AAAAAAAAAAAAAAAAAA”);
Heltec.begin(true /DisplayEnable Enable/, false /LoRa Enable/, true /Serial Enable/, true /PABOST Enale/, BAND);
Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT);
Heltec.display->setContrast(255);
Heltec.display->drawString(0, 0, "Enviando Pacote: ");
Heltec.display->drawString(90, 0, String(contador));
Heltec.display->setFont(ArialMT_Plain_16);
Heltec.display->drawString(0, 22, “Progamador”);
Heltec.display->drawString(0, 45, “Rafael”);
Heltec.display->display();
Serial.print("Enviando: ");
Serial.println(contador);
Heltec.display->clear();
Heltec.display->drawString(0, 0, "Enviando: " + String(contador));
Serial.print("Enviando contador: ");
Heltec.LoRa.beginPacket();
Heltec.LoRa.print("Contador: ");
Heltec.LoRa.print(contador);
Heltec.LoRa.endPacket();
contador++;
delay(2000); // Envie a cada 5 segundos
Heltec.h is the wrong library for V3. You have to use the Radio Lib. But it is difficult to get it working beetween V3 and V2.
https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series,This is Heltec’s development environment, supporting all series of development boards. There are new instances of Lora inside. I hope this will be helpful to you
Hello Rafael-Angelo,
Because I’have the same problem, can you tell me if you resolved your problem?
Thank’s,
Bruno
