Hello everyone,
i am working with the Lorawan OTAA example but the default SF is not working for me and i cant find where to set it.
Could someone please help me?
Thank you in advance.
Best Regards
Ignacio
Spreading Factor setup
It is recommended that you use this function to set:
void setDataRateForNoADR(int8_t dataRate);
Hi Navi and thanks for your help.
I was checking, but i guess i have another problem.
First, Ive been using the lorasender example, and my node works perfect (i have a heltec V2 stick with oled ). I found it on my spectrum analyzer and my packet forwarder works good too.
But i realized when i use the OTAA example, that the module its not tramsitting…I write the AppKey, the license but when i wath my spectrum analyzer i found nothing…Do you guess what i am doing wrong?
Best Regardas
You can check the information printed by the serial port first!
