So I’m not sure what can be the problem, for sure is not a hardware because when I am using the https://github.com/mcci-catena/arduino-lmic library works just fine.
When I’m trying to use ur library I cant see any payload at the application side.
I’m using the OTAA example, with heltec sitck lite.
I’m just adding this line at LoRaMac-definitions.h :
//#define USE_BAND_868
#define USE_BAND_915
And also I’m modifying in Comissing.h:
#define LORAWAN_APPLICATION_EUI
#define LORAWAN_DEVICE_EUI
#define LORAWAN_APPLICATION_KEY
Having this as result:
I cant find where is the problem when I’m using the Heltec Lib =/// . I have already waste to many time on it.
