Hope you can help, I want to restore the code in my Heltec Wifi Kit V3, so that it’s as it was when new. It cam from Heltec with a simple wifi scanner and that’s what I want to restore.
Like a fool, I uploaded the code for the wrong board!!! and want to reload the default code as supplied when the board was new.
Can someone point me to the default as new code on GitHub etc, so that I can load into the board as start again from fresh using either Platformio or Arduino IDE…thanks.
(Solved) Restore Wifi Kit V3 - Help
https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series/tree/0.0.9/esp32/libraries/Heltec-Example/examples/Factory_Test/WiFi_Kit_32_V3_FactoryTest
This may be helpful to you
Thanks all sorted now…Many thnaks
