[SOLVED] Programmatically set ACK request
in my application from time to time I need to send a packet with ACK request. Not for all the packets but from some very_important ones.
is it possible to set the ACK request dinamically in the C code before sending the packet?
I’m not using AT commands (disabled)
thanks
You can set the para “isTxConfirmed” to true/false to send confirmed/unconfirmed uplink before send.
ah! yes, you are correct.
thanks a lot
