I’m using HelTecAutomation/ESP32_LoRaWAN to send large LORA-messages (directly from node to node) for testing reasons (not operational) with
#define TX_OUTPUT_POWER 15 // dBm
#define LORA_BANDWIDTH 1 // [0: 250kHz,
#define LORA_PREAMBLE_LENGTH 0 // Same for Tx and Rx
#define RX_TIMEOUT_VALUE 1000
#define BUFFER_SIZE 300 // Define the payload size here
However the ESP WIFI LoRa 32 V2 stops receiving packets bigger than 64 chars and starts receiving again the first letters, after the packet size is greater than 256.
Is there a bufferlimit or something else, which cause an receiving stop at bigger packets than 64 chars?
Thanks in advance
