Hi there,
I’m working on a project where I need to work with LoRa and WiFi packets. I’m using the ESP32_LoRaWAN-master library for the LoRa part. When I add the WiFi.h library to add the wifi capability to the node I get this error:
C:\Users\Fede\AppData\Local\Arduino15\packages\Heltec-esp32\hardware\esp32\0.0.5/tools/sdk/lib\libwpa_supplicant.a(aes-internal-enc.o): In function `aes_encrypt’:
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/wpa_supplicant/src/crypto/aes-internal-enc.c:124: multiple definition of `aes_encrypt’
libraries\ESP32_LoRaWAN-master\aes.c.o:C:\Users\Fede\Documents\Arduino\libraries\ESP32_LoRaWAN-master\src/aes.c:569: first defined here
collect2.exe: error: ld returned 1 exit status.
I would really appreciate if anybody could give me a hint!
Thanks in advance!
