Solar cubcell stops after about 3 hours?
Cubecell stops after a random amount of wakes and sleeps. looked and edited my code as suggested in other posts. But they still stop working after a couple of hours. Could it be a memory leak or Stack pointer not being reset on wake? Is there a way to test this theory?
2022-12-09T00:00:00Z
#include “LoRaWan_APP.h”
#include “Arduino.h”
#include “time.h”
#include <Wire.h>
#include <string.h>
#include “SHT3x.h”
#ifdef asr650x
#include “innerWdt.h”
  • For asr650x, the max feed time is 2.8 seconds.
  • For asr6601, the max feed time is 24 seconds.
#ifdef asr650x
#define MAX_FEEDTIME 2800// ms // was 2800
#else
#define MAX_FEEDTIME 24000// ms
SHT3x Sensor;
#ifndef LoraWan_RGB
#define LoraWan_RGB = 0 //set both to 1 for led to work
#define TX_OUTPUT_POWER 5 // dBm // WAS 5
                                                          //  1: 250 kHz,
                                                          //  2: 500 kHz,
                                                          //  3: Reserved]
                                                          //  2: 4/6,
                                                          //  3: 4/7,
                                                          //  4: 4/8]
#define RX_TIMEOUT_VALUE 900
#define BUFFER_SIZE 255 // Define the payload size here
uint64_t TxLastTimne ; // timestamp last TX
uint64_t TXinterval; // time until next TX
uint64_t ThisAwake; // time spent awake
byte txpacket[BUFFER_SIZE];
byte rxpacket[BUFFER_SIZE];
bool AllTXdone =false;
byte packetList[255]; // store packets
byte pointer;
float Temp=0;
float Humid=0;
byte TXsize=0;
uint64_t TXchipID=getID();
byte groupID =0; // set group ID to your mesh group. Only matching ID nodes will repeat
byte action =1; // Action 0 is following bytes are Voltage, Temperature,Humidity values
uint16_t volts;
int SleepTime ; //minutes to sleep
int awakeTime =70; //second
byte RecieveSync=0; //
static TimerEvent_t sleep;
static TimerEvent_t wakeUp;
bool BatteryLow;
bool debug=false; ///**** debug with print statements
RadioEvents_t RadioEvents;
void OnTxDone( void );
void OnTxTimeout( void );
typedef enum
WAIT_TX_DONE,
LOWPOWER,
RX,
TX
}States_t;
int16_t txNumber;
States_t state;
bool sleepMode = false;
int16_t Rssi,rxSize;
boardInitMcu( );
CommonBoot();
Radio.Init( &RadioEvents );
 Radio.SetSyncWord(0xF2);
if (debug==true){
  Serial.println(MAX_FEEDTIME);
  Serial.println("Booting from SetUp");
feedInnerWdt(); // feed watchdog timer
if ((millis() - TxLastTimne> TXinterval)&&(state==RX)){
TxLastTimne = millis();            // timestamp the message
state=TX;
switch(state)
case TX:
  TXPacket();
case RX:
case LOWPOWER:
  if (debug==true){
    Serial.println("LOW POWER MODE");
  CySysWdtDisable();
  Serial.println();
  Serial.flush();
  lowPowerHandler();
Radio.IrqProcess( );
void TXPacket(){
if (AllTXdone==true){
  awakeTime=5;    // All done, go into lowpower and sleep in 5 seconds
  SetAwakeTime();
  state=LOWPOWER;
else
  if (debug==true){
    Serial.println("Get a TX packet.");
   TXpacketGet();
   if (AllTXdone==false){
    //turnOnRGB(COLOR_SEND,0);
    //turnOnRGB(0x000050,0);// blue help shine through case
    Radio.Send( (uint8_t *)txpacket,TXsize); // *** remember to change the packet length to send
    TXPacketPrint();
    state=WAIT_TX_DONE;
if (debug==true){
Serial.print("TX done......\r\n");
turnOnRGB(0,0);
awakeTime=60; // just stay awake for another 10 seconds to see if any other node joins or transmits
SetAwakeTime();
Radio.Rx( 0 );
state=RX;
Radio.Sleep();
if (debug==true){
  Serial.print("TX Timeout......");
Radio.Rx( 0 );
state=RX;
Rssi=rssi;
rxSize=size;
//turnOnRGB(COLOR_RECEIVED,0);
Radio.Sleep();
if (rxSize==18){  // found a potential node packet
  if (rxpacket[6]==groupID){ // group ID matches to add the packet to the repeat que
    RXpacketApend();
    RecieveSync=3;  // reset sycn to keep trying for 2 attempts so could lose contact for 3 hours
    SleepTime=20;   // sycned so sleep and wake together every 20 minutes
    awakeTime=10;    // just stay awake for another 10 seconds to see if any other node joins or transmits
    SetAwakeTime();
Radio.Rx( 0 );
state=RX;
void TXpacketInsert(){
pointer=1;     // start at position 1 to insert packet length at 0
volts = getBatteryVoltage();
if (debug==true){
  Serial.printf("ChipID:%04X%08X\r\n",(uint32_t)(TXchipID>>32),(uint32_t)TXchipID);
  Serial.printf("Battery:");
  Serial.println((float)volts/1000);
SHT30();
byte *aStr = new byte[8];
byte *bStr =  new byte[8];
byte *cStr =  new byte[8];
packetList[pointer]=0; // transmit recieve counter
pointer++;
int64ToChar(aStr, TXchipID);
for (int i=0;i<6;++i) {
  packetList[pointer]=aStr[i];
  pointer++;
packetList[pointer]=groupID; // Group ID location 6
pointer++;
packetList[pointer]=action;  // action location 7
pointer++;
int16ToChar(bStr, volts);
for (int i=0;i<2;++i) {
  packetList[pointer]=bStr[i];
  pointer++;
floatToChar(cStr,Temp);  // pack in temperature in packet
for (int i=0;i<4;++i) {
  packetList[pointer]=cStr[i];
  pointer++;
floatToChar(cStr,Humid);
  pointer++;
packetList[pointer]=0; // End terminated ready for appending
packetList[0]=pointer; // put the packet length at the start.
void TXpacketGet(){
byte BasePoint=0;
pointer=0;
TXsize=0;
while (packetList[BasePoint+pointer]!=0) {
TXsize=packetList[BasePoint+pointer]-2;
  pointer++;
  if (packetList[BasePoint+pointer]<2){
    packetList[BasePoint+pointer]++;  // increment it as going to transmit this one
    pointer++; // incement to point at packet data
    for (int i=0;i<TXsize;++i) {
      txpacket[i]=packetList[BasePoint+pointer];
      pointer++;
    awakeTime=60;    // seconds
    SetAwakeTime();
    return;
BasePoint+=20;
pointer=0;
TXsize=0;
if (debug==true){
Serial.println(“Nothing to send”);
AllTXdone=true;
Radio.Rx( 0 );
state=RX;
void RXpacketApend(){
byte BasePoint=0;
pointer=0;
while (packetList[BasePoint+pointer]!=0){ // look for end zero
bool match=true;
pointer++; // Now pointing at TX RX count
pointer++; // Now pointing at Data
for (int i=0;i<rxSize;++i) {
if ((packetList[BasePoint+pointer]!=rxpacket[i])&&(i<8)){  // Compare ID's only
  match=false;
pointer++;
if (match==true) { // packet already in list don’t append just add recieved count and return
if (debug==true){
  Serial.println("RX-packet matched already");
packetList[BasePoint+1]++;
return;
//BasePoint+=packetList[BasePoint]; // point to start of next packet and test match again
BasePoint+=20;
pointer=0;
if (BasePoint+rxSize>254){
Serial.print("Append packet full");
return;        // if buffer full do not append
packetList[BasePoint+pointer]= rxSize+2;
pointer++;
packetList[BasePoint+pointer]=0; // transmit recieve counter
pointer++;
for (int i=0;i<rxSize;++i) {// check for matching ID and payload
packetList[BasePoint+pointer]=rxpacket[i];
pointer++;
packetList[BasePoint+pointer]=0; // End terminated ready for appending
if (debug==true){
Serial.println("New Packet appended at");
Serial.println( BasePoint);
packetList[1]=1; // Send this Device again to confirm new recieved device has it.
void TXPacketPrint(){
int pointer =0;
for (int i=0;i<8;++i) { // get Chip ID
aStr[i]=txpacket[pointer];
pointer++;
int64_t RXchipID = charTo64bitNum(aStr);
if (debug==true){
Serial.printf("TX-ChipID:%04X%08X\r\n",(uint32_t)(RXchipID>>32),(uint32_t)RXchipID);
for (int i=0;i<2;++i) { // get battery voltage from packet
bStr[i]=txpacket[pointer];
pointer++;
volts=charTo16bitNum(bStr);
if (debug==true){
Serial.printf(“TX-Battery:”);
for (int i=0;i<4;++i) { // get temperature from packet
cStr[i]=txpacket[pointer];
pointer++;
Temp= charTofloatNum(cStr);
if (debug==true){
Serial.print("TX-Temperature: ");
Serial.print(Temp);
Serial.write("\xC2\xB0"); //The Degree symbol
Serial.println("C");
for (int i=0;i<4;++i) { // get Humidity from packet
pointer++;
Humid= charTofloatNum(cStr);
if (debug==true){
Serial.print("TX-Humidity   : ");
Serial.print(Humid);
Serial.println("%");
Serial.println("------------------------");
void onSleep(){
Radio.Sleep( );
turnOnRGB(0,0);
if (debug==true){
Serial.printf("Going to sleep for %d Minutes....\r\n",SleepTime);
Serial.println();
Serial.flush();
state=LOWPOWER;
//TimerStop(&wakeUp);
TimerSetValue( &wakeUp, (SleepTime *60000));
TimerStart( &wakeUp );
void SetAwakeTime(){
if (debug==true){
Serial.printf(“Awake for %d Seconds…\r\n”,awakeTime);
//TimerStop(&sleep);
TimerSetValue( &sleep, awakeTime*1000);
TimerStart( &sleep );
void onWakeUp(){
CommonBoot();
if (debug==true){
Serial.println(“Just Woke Up”);
void CommonBoot(){
CySysWdtEnable();
//innerWdtEnable(true);
Sensor.Begin();
if (RecieveSync==0){ // lost sync or no nodes so go into long listen short sleep mode.
SleepTime=constrain(map(volts,3500,3000,2,90),2,90); // sleep for longer to charge from solar
//SleepTime=2;
else
SleepTime=30; // sycnd , so wake every 30 minutes to exchange data
awakeTime=60;
if(RecieveSync>0){
RecieveSync--;
TXpacketInsert();
TXinterval =20000; //between 2.5 and 7.5 seconds next T
TimerInit( &sleep, onSleep );
SetAwakeTime();
Radio.Rx( 0 );
state=RX;
AllTXdone=false;
if (debug==true){
Serial.println("");
TXinterval =20000; //between 2.5 and 7.5 seconds next TX
if ((volts)<3000){
BatteryLow=true;
if ((volts)>3100){
BatteryLow=false;
if (BatteryLow==true){
SleepTime=240; // battery is flat and risks a brownout WDT trigger so sleep for 4 hours to charge
awakeTime=5; // seconds
RecieveSync=0; // no chance we will wake from recharge with sync so wake as lost sync
state=LOWPOWER; // Just go lowpower mode and sleep ASAP
void SHT30() {
// Vext ON
digitalWrite(Vext, LOW);
delay(500);
Sensor.UpdateData();
if (Humid==0){ // error reading so try again
Temp=Sensor.GetTemperature();
if (debug==true){
Serial.print("Temperature: ");
Serial.print(Temp);
Humid=Sensor.GetRelHumidity();
if (debug==true){
Serial.print("Humidity   : ");
 Wire.end();
 delay(50);
// Vext OFF
digitalWrite(Vext, HIGH);
// Service routines…
void int64ToChar(byte a[], int64_t n) {
memcpy(a, &n, 8);
void int16ToChar(byte a[], int16_t n) {
memcpy(a, &n, 2);
void floatToChar(byte a[], float f) {
memcpy(a, &f, sizeof(float));
int64_t charTo64bitNum(byte a[]) {
int64_t n = 0;
memcpy(&n, a, 8);
return n;
int16_t charTo16bitNum(byte a[]) {
int16_t n = 0;
memcpy(&n, a, 2);
return n;
float charTofloatNum(byte a[]) {
float n = 0;
memcpy(&n, a, sizeof(float));
return n;
You can try to check the serial port log. If there is an error, it will print out.
I think it might be lowPowerHandler() not looped through enough or complete, before OnSleep() happens. I have added a longer wake time from 5 seconds to 10 . To see if it solves it. it would be nice to have a way of knowing the lowPowerHandler is complete . like WHILE (lowPowerHandler()==false). I have read that LowPowerHandler has been updated and only needs to called once. But my code needs to call it a few times in the loop. How can i tell what version i am running? I am using Visual Studio code. As i can’t get the github jason for heltec to work with Arduino.
Yes with serial port logging. The problem is lowPowerHandler() stopping the board from going to sleep. and hanging there. So what is the solution?
Just one suggestion. I’ve not had this exact problem, but I did manage to get things working consistently by:
  1. Having everything inside the main loop within one of the cases of the switch statement (this may not be critical, but it may help you structure things the right way);
  2. Having the call to the lowPowerHandler() as the only code in the LOWPOWER case (other than the break statement).
The lowPowerHandler() (used to?) cycles around several times waiting for tasks to finish, but I found that if you do anything else within the LOWPOWER case, other than call the lowPowerHandler(), things can end up not working as you might expect. Any sort of Serial output there can be problematic because even trivial stuff is time consuming (in a relative sense).
So, maybe see if you can restructure your code to do those other things you currently have in the LOWPOWER case before you actually set the state to LOWPOWER and pass through the loop to call the lowPowerHandler().
(Another tip: You should be able to include all of your code, when posting on a forum, in a single scrollable box by selecting it and marking it as ‘Preformated Text’ (the little </> icon up on the menu bar).)
Program still locked up after tidying up the code so everything is done before low power mode. I have now moved Radio.IrqProcess( ); out of the loop so they are procced all other states apart form LOWPOWER state. And on test now. Really running out of ideas now. Can some one post a simple working version of pingpong that sleeps and wakes? So i can build my code from that.
#include "Arduino.h"
#include "time.h"
#include <Wire.h>
#include <string.h>
#include "SHT3x.h"
#ifdef __asr650x__
#include "innerWdt.h"
 * For asr650x, the max feed time is 2.8 seconds.
 * For asr6601, the max feed time is 24 seconds.
#ifdef __asr650x__
#else
SHT3x Sensor;
#ifndef LoraWan_RGB
                                                              //  1: 250 kHz,
                                                              //  2: 500 kHz,
                                                              //  3: Reserved]
#define LORA_SPREADING_FACTOR                       7        // [SF7..SF12]
                                                              //  2: 4/6,
                                                              //  3: 4/7,
                                                              //  4: 4/8]
uint64_t TxLastTime ;         // timestamp last TX
uint64_t TXinterval= 15000;   // time until next TX
byte pointer;
float Temp=0;
float Humid=0;
byte TXsize=0;
uint16_t volts;
int awakeTime ;   //second
bool BatteryLow;
typedef enum
    WAIT_TX_DONE,
    LOWPOWER,
    RX,
    SLEEP_NOW,
    TX
}States_t;
int16_t txNumber;
States_t state;
    boardInitMcu( );
    CommonBoot();
    if (debug==true){
  Radio.Rx( 0 );
  state=RX;
  //feedInnerWdt();   // feed watchdog timer
  if ((millis() - TxLastTime> TXinterval)&&(AllTXdone==false)){
    TxLastTime = millis();            // timestamp the message
    state=TX;
  switch(state)
    case TX:
      TXPacket();
    case RX:
    case WAIT_TX_DONE:
    case LOWPOWER:
      lowPowerHandler();
void TXPacket(){
      awakeTime=10;    // All done, go into lowpower and sleep in 10 seconds
      SetAwakeTime();
      if (debug==true){
      Serial.printf("And then Sleep for %d Minutes..\r\n",SleepTime);
      Radio.Rx(0);
      turnOnRGB(0,0);
      Serial.println();
      Serial.flush();
      state=LOWPOWER;
    else
      if (debug==true){
       TXpacketGet();
        if (debug==true){
        TXPacketPrint();
        state=WAIT_TX_DONE;
  if (debug==true){
  turnOnRGB(0,0);
  awakeTime=20;    // just stay awake for another 20  seconds to see if any other node joins or transmits
  SetAwakeTime();
  Radio.Rx( 0 );
  state=RX;
    Radio.Sleep();
    if (debug==true){
    Radio.Rx( 0 );
    state=RX;
    Rssi=rssi;
    rxSize=size;
        RXpacketApend();
        awakeTime=20;    // just stay awake for another 30 seconds to see if any other node joins or transmits
        SetAwakeTime();
  Radio.Rx( 0 );
  state=RX;
    if (debug==true){
     SHT30();
    pointer++;
      pointer++;
    pointer++;
    pointer++;
      pointer++;
      pointer++;
      pointer++;
void TXpacketGet(){
  byte BasePoint=0;
  pointer=0;
  TXsize=0;
      pointer++;
          pointer++;
        SetAwakeTime();
        return;
    BasePoint+=20;
    pointer=0;
TXsize=0;
 if (debug==true){
  Serial.println("Nothing to send");
 AllTXdone=true;
  byte BasePoint=0;
  pointer=0;
  bool match=true;
      match=false;
    pointer++;
   if (match==true) {                    // packet already in list don't append just add recieved count and return
    if (debug==true){
    return;
  BasePoint+=20;
  pointer=0;
  pointer++;
  pointer++;
    pointer++;
  if (debug==true){
  packetList[1]=1; // Send this Device packet again to forward it and to confirm it from sender
  int pointer =0;
    pointer++;
    pointer++;
  Serial.printf("TX-Battery:");
    pointer++;
    Serial.print(Temp);
    pointer++;
void onSleep(){
void SetSleepTime(){
if (debug==true){
  Serial.printf("Sleep for %d Minutes..\r\n",SleepTime);
if (debug==true){
  Serial.printf("Awake for %d Seconds..\r\n",awakeTime);
void onWakeUp(){
  if (debug==true){
  Serial.println("Wake from sleep");
  CommonBoot();
  Radio.Rx( 0 );
  state=RX;
void  CommonBoot(){
//CySysWdtEnable();
Sensor.Begin();
    SleepTime=constrain(map(volts,3700,3000,2,30),2,30); // sleep for longer to charge from solar
  else
  if(RecieveSync>0){
    RecieveSync--;
  TXpacketInsert();
  awakeTime=60;
  AllTXdone=false;
  if (debug==true){
    Serial.println("");
  if ((volts)<3000){
    BatteryLow=true;
if ((volts)>3100){
    BatteryLow=false;
   awakeTime=10;    // seconds
  AllTXdone=true;  // Don't even bother looking to TX anything.
  SetAwakeTime();
void SHT30() {
  // Vext ON
    delay(500);
if (Humid==0){        // error reading third time lucky
  if (debug==true){
    Serial.print(Temp);
  if (debug==true){
     Wire.end();
     delay(50);
   // Vext OFF
// Service routines.......................................................................................
  memcpy(a, &n, 8);
  memcpy(a, &n, 2);
  int64_t n = 0;
  memcpy(&n, a, 8);
  return n;
  int16_t n = 0;
  memcpy(&n, a, 2);
  return n;
  float n = 0;
  return n;
}`Preformatted text`
Update: moving Radio.IrqProcess(); did not solve the lock up and seemed to make it happen earlier. Coming from ESP32’s , I have never had such a problem that seems to happen every time but after a random time. With a program that is just looping through the same code over and over. Which just got me thinking. random crashing? So i added print statements to see if the program stopped in random sections of code. But it actually stops a certain part of my code every time. Just about here
Normally i just allocate memory with byte aStr[8]={0};
But instead this time i copied the above code from a ESP32 example without understanding what ‘new’ does.
So knowing my code freezes here. I investigated what new does and it allocates a fresh dynamic array on the heap.And that i am supposed to un-allocate it when done.So i guess the heap was getting bigger and bigger until it broke the code. Testing updating code over night, and hopefully it will still be running in the morning.
Yeah, similar problem here. I had to develop a separate code base (from the ESPs) for the ASR processors when I started working with them, but the low power characteristics and integrated solar power management of the ASR/CubeCell were enough to make the effort worthwhile at the time. The game changes quickly though and the new ESP32-S3s claim to have improved low power characteristics, so we’ll see how they go.
After using code below, the code is now worked over night without crashing.
Next I will add code to my second cubcell and leave them outside to see if they can maintain connection in the winter sun and low temperatures.
Solar cubcells are out of stock for my region at the moment.
So can’t test the mesh repeater functionality i have built into my code.
I have a couple of TTGO esp32 lora modules which i will code to replicate the cubcell operation
to test the mesh capability
Next i will add capability for other of the range of sensors.
indent preformatted text by 4 spaces
#include "time.h"
#include <Wire.h>
#include <string.h>
#include "SHT3x.h"
#ifdef __asr650x__
#ifdef __asr650x__
#else
SHT3x Sensor;
#ifndef LoraWan_RGB
                                                              //  1: 250 kHz,
                                                              //  2: 500 kHz,
                                                              //  3: Reserved]
                                                              //  2: 4/6,
                                                              //  3: 4/7,
                                                              //  4: 4/8]
byte pointer;
float Temp=0;
float Humid=0;
byte TXsize=0;
uint16_t volts;
bool BatteryLow;
bool debug=true;      ///**** debug with print statements
typedef enum
    WAIT_TX_DONE,
    LOWPOWER,
    RX,
    SLEEP_NOW,
    TX
}States_t;
int16_t txNumber;
States_t state;
    boardInitMcu( );
    CommonBoot();
    if (debug==true){
  Radio.Rx( 0 );
  state=RX;
    state=TX;
  switch(state)
    case TX:
      TXPacket();
    case RX:
    case WAIT_TX_DONE:
    case LOWPOWER:
      lowPowerHandler();
void TXPacket(){
      SetAwakeTime();
      if (debug==true){
      Radio.Rx(0);
      turnOnRGB(0,0);
      Serial.println();
      Serial.flush();
      state=LOWPOWER;
    else
      if (debug==true){
       TXpacketGet();
        Radio.Send( (uint8_t *)txpacket,18); // *** packet length is 18
        if (debug==true){
        TXPacketPrint();
        state=WAIT_TX_DONE;
  if (debug==true){
  turnOnRGB(0,0);
  SetAwakeTime();
  Radio.Rx( 0 );
  state=RX;
    Radio.Sleep();
    if (debug==true){
    Radio.Rx( 0 );
    state=RX;
    Rssi=rssi;
    rxSize=size;
        RXpacketApend();
        SetAwakeTime();
  Radio.Sleep( );
  Radio.Rx( 0 );
  state=RX;
    if (debug==true){
     SHT30();
    byte aStr[8]={0};
    byte bStr[8]={0};
    byte cStr[8]={0};
    pointer++;
      pointer++;
    pointer++;
    pointer++;
      pointer++;
      pointer++;
      pointer++;
  if (debug==true){
  Serial.println("Packet insert OK");
void TXpacketGet(){
  byte BasePoint=0;
  pointer=0;
  TXsize=0;
      pointer++;
          pointer++;
        SetAwakeTime();
        return;
    BasePoint+=20;
    pointer=0;
TXsize=0;
 if (debug==true){
 AllTXdone=true;
  byte BasePoint=0;
  pointer=0;
  bool match=true;
      match=false;
    pointer++;
    if (debug==true){
    return;
  BasePoint+=20;
  pointer=0;
  pointer++;
  pointer++;
    pointer++;
  if (debug==true){
  byte aStr [8]={0};
  byte bStr [8]={0};
  byte cStr [8]={0};
  int pointer =0;
    pointer++;
    pointer++;
    pointer++;
    Serial.print(Temp);
    pointer++;
void onSleep(){
if (debug==true){
if (debug==true){
void onWakeUp(){
  if (debug==true){
  CommonBoot();
  Radio.Rx( 0 );
  state=RX;
void  CommonBoot(){
//CySysWdtEnable();
Sensor.Begin();
    SleepTime=constrain(map(volts,3700,3000,2,90),2,90); // sleep for longer to charge from solar
  else
  if(RecieveSync>0){
    RecieveSync--;
  TXpacketInsert();
  awakeTime=60;
  AllTXdone=false;
  if (debug==true){
    Serial.println("");
  if ((volts)<3000){
    BatteryLow=true;
if ((volts)>3100){
    BatteryLow=false;
  SetAwakeTime();
if (debug==true){
  Serial.println("Common Boot OK");
void SHT30() {
  // Vext ON
    delay(500);
  if (debug==true){
    Serial.print(Temp);
  if (debug==true){
     Wire.end();
     delay(50);
   // Vext OFF
  memcpy(a, &n, 8);
  memcpy(a, &n, 2);
  int64_t n = 0;
  memcpy(&n, a, 8);
  return n;
  int16_t n = 0;
  memcpy(&n, a, 2);
  return n;
  float n = 0;
  return n;
