softSerial RX pin high
I’am using AB-02A and need software serial to work. Using GPIO2 for RX from the example doesn’t work for me because it doesn’t set to high at initialization. Changing mode to INPUT_PULLUP didn’t change status. Replace GPIO2 with GPIO8, everything works. My guess is that work because GPIO8 is also SCL1, so it must have internal pull-up resistor.
My question is would AB-01 work? I doesn’t have connection on the board for the GPIO8, so must use some other GPIO.
You can refer to this original picture to choose the pin you need.
