Softserial -HTCC-AB01
Hello everyone, I am working on my final project using a HTCC-AB01 module to which I connect different sensors (gps, gas detector, laser distance detector, soil moisture sensor). The sensors work at different bauds, I am using the softSerial library for communication on pins GPIO5 and GPIO0, but since they work at different bauds, I am trying to use another two pins for the communication of another sensor. Can I use the same communication (softSerial) on other two pins at the same time? Because it hasn’t worked for me, or, how can I have other softSerials communicating with another sensor at another baund rate?
PS: I can’t use the TX and RX pins because I reserve them for communication with another module.
I would appreciate if you help me.
#include <softSerial.h>
softSerial mySerial(GPIO5, GPIO0);//TX, RX
//softSerial lsSerial(GPIO1, GPIO4); not work
boolean ok=false, repe=false;
byte inBuffer[26];
int bufIndx = 0;
float temperature, co2, humidity ,ch2O, co, o3, no2, pm2_5, voc;
mySerial.begin(9600); //MULtiplexor UART (gas, gps)
// lsSerial.begin(19200); //laser 19200
Serial.begin(9600);
pinMode(GPIO2, OUTPUT); //A
pinMode(GPIO3 , OUTPUT); //B
// pinMode(Vext, OUTPUT);
// consulta();
You can try reinitialize serial port before each communication.
Hi Navi, thanks for your answer and how you can reinitialize it to change the baud value, I’m pretty new to all this.
