I’m so stupid that I’ve broken the antenna connector when I’ve removed the antenna.
So … Have I to throw away the board ?
With an gateway near is working … but … another whay to connect an antenna ?
So stupid with the antenna connector
You can try to solder by yourself, the ground wire and signal wire of the antenna
