I took a HT-M2808 miner from my brother and trying to register it/transfer location but it always gets stuck.
I using latest helium black wallet. deposited enough sol and hnt in it.
I am using latest helium app v1.1.4
the miner is on latest firmware: v1.4.6
I can connect via web interface and can connect via BT.
I found out that trying to register it/transfer location using wifi is useless and just gets stuck. and gives this error:
invalid link - unable to add this hotspot to the helium network. contact
heltec to troubleshoot this issue
So i moved to ethernet on the hotspot, this still gives the same error on trying to register.
But if i try to transfer location, the wizard actually finds the location, says it will cost 10$ (no problem i have enough sol/hnt in the wallet) and then gets to the screen:
“update location ?” with a ‘cancel’ and ‘confirm’ button. i can click the ‘confirm’ many times but it will not go ahead from this screen and seems stuck.
Help ? Tips ?
Another note is this hotspot worked on solana previously at my brothers house.
