Hello thanks for being interested in my topic, connect a 4.7k pull up resistor and nothing happened, change to 1k and it started working, but it does not recognize any command, to all AT commands it responds: + ERROR: imput format error.
I attach some screenshots
as for the code I am using the LORAWAN example provided in the Arduino IDE
#include "LoRaWan_APP.h"
#include "Arduino.h"
* RGB red means sending;
* RGB blue means RxWindow1;
* RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t devEui[] = { 0x00, 0xBB, 0x93, 0xB0, 0x9A, 0x01, 0x51, 0xD3 };
uint8_t appEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x03, 0xA5, 0x73 };
uint8_t appKey[] = { 0xBE, 0x55, 0x84, 0xD5, 0x43, 0x34, 0xDA, 0xC5, 0x8F, 0x48, 0x3A, 0xE3,
0xCD, 0xD4, 0xD4, 0xB5 };
/* ABP para*/
uint8_t nwkSKey[] = { 0x15, 0xb1, 0xd0, 0xef, 0xa4, 0x63, 0xdf, 0xbe, 0x3d, 0x11, 0x18, 0x1e, 0x1e,
0xc7, 0xda,0x85 };
uint8_t appSKey[] = { 0xd7, 0x2c, 0x78, 0x75, 0x8c, 0xdc, 0xca, 0xbf, 0x55, 0xee, 0x4a, 0x77, 0x8d,
0x16, 0xef,0x67 };
/*OTAA or ABP*/
/*ADR enable*/
/* set LORAWAN_Net_Reserve ON, the node could save the network info to flash, when node reset
not need to join again */
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
*if enabled AT, don't modify LORAWAN_APP_DATA_MAX_SIZE, it may cause system hanging or
failure.
*if disabled AT, LORAWAN_APP_DATA_MAX_SIZE can be modified, the max value is reference
to lorawan region and SF.
*the max value for different DR can be found in MaxPayloadOfDatarateCN470 refer to
DataratesCN470 and BandwidthsCN470 in "RegionCN470.h".
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
the configuration is this
