Sensors and Accessories for the CubeCell Capsule
This Sensors do work directly with the capsule (Plug and Play):
CubeCell Capsule Sensor Board with BME680
CubeCell Capsule Sensor Board with BME280
CubeCell Capsule Sensor Board with CJMCU-8128
CubeCell Capsule Sensor Board with CCS811, BME280 and BH1750
CubeCell Capsule Sensor Board with BME680 and BH1750
for the MJMCU-8128 Sensor you need a new cap for the sensor side of the capsule:
Capsule CAP for bigger sensors
LiPo Batteries for the Capsule:
Battery 100mAh for Capsule
@rsmedia Could you kindly suggest sensors which can be used with cubecell
  1. For detecting water leak (rope based) . I found one in aliexpress will this work ?)
    https://www.aliexpress.com/item/4000041803534.html?spm=a2g0s.9042311.0.0.4b3a4c4dMcDah6)
  2. Temperature / humidity sensor (rope based). I found one in aliexpress. Will this work (https://www.aliexpress.com/item/4000391670763.html?spm=a2g0s.9042311.0.0.3e884c4do0tN52)
Can we use above 2 sensors together with cubecell ?
Thank you
the BS18B20 is only a temperature sensor, no humidity and is using the OneWire protocol.
right now my firmwares are not supporting oneWire because the scan sometimes let the cubecell hang.
i am debugging this right now and hope to have firmware with onewire support up next week.
for your water leak sensor you will need a little more electronic. to use the gpios you need a digital signal with 0 for dry and 1 for wet for example.
@rsmedia i will be very happy to test your firmware using onewire protocol support. Currently i have ordered 2 boards from heltec and is waiting for their delivery. Once I get it will test it with your cubecell configurator. It would be also nice if you can add support for IN865-867 band for india in your configurator. Thanks again.
@BDM i now have the IN865 band added in the configurator and uploaded the firmware files.
now without OneWire. But hope to have a stable version with OneWire next week.
@rsmedia. Thanks for your efforts and the contribution to the community
