If connected a sound-level module to my AB01 Cubecell board.
I’ve connected the out pin to GPIO0. I want it so send me a lorawan message by interrupt, every moment it detects a bang, preferably with the level measured by the ADC. I’ve used this sketch to start with:
With the modification a made it sends a message only at the first time it detects a bang. Below here is my current (platformio) sketch. I hope someone can point me in the right direction for the cause of my problem.
#include “LoRaWan_APP.h”
#include “Arduino.h”
/* OTAA para*/
uint8_t devEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t appKey[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
/* ABP para*/
// The interrupt pin is attached to GPIO0
#define INT_PIN GPIO0 //interuptpin for soundsensormodule
// battery voltage
uint16_t vbat;
// measurured SoundLevel value from ADC
int soundlevel;
/* Application port */
#define DEVPORT 2
#define APPPORT 1
bool accelWoke = false;
/*For this example, this is the frequency of the device status packets */
uint32_t appTxDutyCycle = (24 * 60 * 60 * 1000); // 24h;
/OTAA or ABP/
/ADR enable/
/* Application port /
uint8_t appPort = DEVPORT;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
static bool prepareTxFrame( uint8_t port )
int head;
appPort = port;
switch (port) {
case APPPORT: // woke up from interrupt
Serial.println(“Sending data packet”);
soundlevel = analogRead(INT_PIN); //Read the ADC value from the soundsensor
Serial.print(“soundlevel:”);
Serial.println(soundlevel);
appDataSize = 2;//AppDataSize max value is 64
//appData[0] = 0xFF; // set to something useful
appData[0] = highByte(soundlevel);
appData[1] = lowByte(soundlevel);
case DEVPORT: // daily wake up
Serial.println(“Sending dev status packet”);
vbat = getBatteryVoltage();
//appData[0] = 0xA0; // set to something else useful
appData[0] = highByte(vbat);
appData[1] = lowByte(vbat);
return true;
void accelWakeup()
delay(10);
if(digitalRead(INT_PIN)==HIGH)
accelWoke = true;
boardInitMcu();
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
//Vext ON
pinMode(Vext,OUTPUT);
digitalWrite(Vext,LOW);
delay(500);
accelWoke = false;
pinMode(INT_PIN,INPUT_PULLUP);
attachInterrupt(INT_PIN, accelWakeup, RISING);
Serial.println(“Interrupts attached”);
if (accelWoke) {
uint32_t now = TimerGetCurrentTime();
Serial.print(now); Serial.println(“accel woke”);
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( DEVPORT );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
if (accelWoke) {
if (IsLoRaMacNetworkJoined) {
if(prepareTxFrame(APPPORT)) {
LoRaWAN.send();
accelWoke = false;
Serial.println(“accel woke false”);
LoRaWAN.sleep();
