Sending sensor data using cayenne
I’m trying to modify the example named “LoRaWan_downlinkdatahandle” to send sensor date using the Cayenne LPP library.
I modified the prepareTxFrame function :
/appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
lpp.reset();
lpp.addTemperature(4, bmp.readTemperature());
lpp.addBarometricPressure(7,(bmp.readPressure()/100.0));
appDataSize = lpp.getSize();
appData=lpp.getBuffer();
And i obtain an error :
Arduino : 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Carte : “WiFi LoRa 32(V3) / Wireless shell(V3) / Wireless stick lite (V3), Core 1, Core 1, 240MHz (WiFi), 115200, None, REGION_EU868, None, CUSTOM, 8(default)”
C:\Users\tanguy-e\Documents\Arduino\LoRa\LoRaWan_downlinkdatahandle\LoRaWan_downlinkdatahandle.ino: In function ‘void prepareTxFrame(uint8_t)’:
LoRaWan_downlinkdatahandle:83:27: error: incompatible types in assignment of ‘uint8_t*’ {aka ‘unsigned char*’} to ‘uint8_t [255]’ {aka ‘unsigned char [255]’}
exit status 1
I’m quite a newbie and i can’t understand this type mismatch and how to solve it.
Eric
#include “LoRaWan_APP.h”
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#include <CayenneLPP.h>
CayenneLPP lpp(51);
/* OTAA para*/
uint8_t devEui[] = { 0x70, 0xb3, 0xd5, 0x7e, 0xd0, 0x05, 0xe8, 0xee }; /* Pas utile si Generate by ChipID is selected */
uint8_t appKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88 };
/* ABP para*/
uint8_t nwkSKey[] = { 0xfa, 0x4e, 0x25, 0x1e, 0x89, 0x48, 0x3a, 0x53, 0x63, 0x8c, 0xcb, 0x6e, 0xbf, 0xdf, 0x25,0x1b };
uint8_t appSKey[] = { 0x13, 0x5c, 0xe2, 0x94, 0xea, 0x55, 0x63, 0xa1, 0xb4, 0x12, 0xe2, 0x8a, 0x97, 0x48, 0xb5,0x93 };
uint32_t devAddr = ( uint32_t )0x260b1d21;
/OTAA or ABP/
/ADR enable/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port /
uint8_t appPort = 2;
  • Number of trials to transmit the frame, if the LoRaMAC layer did not
  • receive an acknowledgment. The MAC performs a datarate adaptation,
  • according to the LoRaWAN Specification V1.0.2, chapter 18.4, according
  • to the following table:
  • Transmission nb | Data Rate
  • 1 (first) | DR
  • 2 | DR
  • 3 | max(DR-1,0)
  • 4 | max(DR-1,0)
  • 5 | max(DR-2,0)
  • 6 | max(DR-2,0)
  • 7 | max(DR-3,0)
  • 8 | max(DR-3,0)
  • Note, that if NbTrials is set to 1 or 2, the MAC will not decrease
  • the datarate, in case the LoRaMAC layer did not receive an acknowledgment
    Adafruit_BMP280 bmp;
/appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
lpp.reset();
//downlink data handle function example
Serial.printf("+REV DATA:%s,RXSIZE %d,PORT %d\r\n",mcpsIndication->RxSlot?“RXWIN2”:“RXWIN1”,mcpsIndication->BufferSize,mcpsIndication->Port);
Serial.printf(“Données reçues : \n”);
Serial.print("+REV DATA:");
for(uint8_t i=0;iBufferSize;i++)
Serial.println();
uint32_t color=mcpsIndication->Buffer[0]<<16|mcpsIndication->Buffer[1]<<8|mcpsIndication->Buffer[2];
#if(LoraWan_RGB==1)
turnOnRGB(color,5000);
turnOffRGB();
unsigned status;
status = bmp.begin(BMP280_ADDRESS_ALT, BMP280_CHIPID);
if (!status) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
“try a different address!”));
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. /
Adafruit_BMP280::SAMPLING_X2, /
Temp. oversampling /
Adafruit_BMP280::SAMPLING_X16, /
Pressure oversampling /
Adafruit_BMP280::FILTER_X16, /
Filtering. /
Adafruit_BMP280::STANDBY_MS_500); /
Standby time. */
Mcu.begin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass);
Hi !
Have you find a workaround ?
Hi
Yes instead of
lpp.reset();
use
lpp.reset();
lpp.addBarometricPressure(7, (bmp.readPressure() / 100.0));
int compteur;
for (compteur = 0 ; compteur < appDataSize ; compteur++)
appData[compteur] = lpp.getBuffer()[compteur];
