My setup is an M02 and a couple of AB02’s with sensors.
The sensor data is being published on the M02 and a remote application is subscribed and receiving that data.
On the cubecell there are a couple of config variables I would like to alter from time to time, these are the alert level for the temperature and the sample time for the sensor. Ideally i would like to send this infor using MQTT and have tried sending the data to application/91/device/2232330000888802/tx but im not seeing anyting on the cubecell.
I can send hex values via the M02 and that works but in this situation the config will have to come from another application.
