Send Sensor Signal
Very new at all this stuff and I’ve been trying to learn over the last couple weeks; and while I have come far; I am in need of your help…
How do I actually send my sensor data?
I have a Wireless Stick v3 with a sound sensor hooked up.
sound_analog = A4
sound_digital = 47
Basically when sound_digital goes to 1, I’d like the stick to wake up and send “Sound Sensor” or something…
I keep reading different things, but since I’m learning, I’m getting lost… Any input would help greatly! Sorry there is a bunch of extra stuff in this code, I’ve been trying all kinds of crazy things.
indent preformatted text by 4 spaces
#include <LoRaWan_APP.h>
#define WIRELESS_STICK_V3
#define INT_PIN 0
//______________Sound Sensor
int led = 46;
int sound_analog = A4;
int sound_digital = 47;
/* OTAA para*/
uint8_t devEui[] = { 0x0b, 0xb8, 0xd4, 0xa7, 0x24, 0x65, 0x64, 0x23 };
uint8_t appKey[] = { 0x16, 0xfb, 0xb0, 0x5b, 0xbb, 0x87, 0xdb, 0x86, 0x4a, 0x7c, 0x74, 0xf4, 0xed, 0xdf, 0x6b, 0xf5 };
/* ABP para*/
uint32_t devAddr = ( uint32_t )0x002e6ae1;
uint32_t appTxDutyCycle = 300000; //was 3600241000 set to 5min for testing
/OTAA or ABP/
/ADR enable/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
  • Number of trials to transmit the frame, if the LoRaMAC layer did not
  • receive an acknowledgment. The MAC performs a datarate adaptation,
  • according to the LoRaWAN Specification V1.0.2, chapter 18.4, according
  • to the following table:
  • Transmission nb | Data Rate
  • 1 (first) | DR
  • 2 | DR
  • 3 | max(DR-1,0)
  • 4 | max(DR-1,0)
  • 5 | max(DR-2,0)
  • 6 | max(DR-2,0)
  • 7 | max(DR-3,0)
  • 8 | max(DR-3,0)
  • Note, that if NbTrials is set to 1 or 2, the MAC will not decrease
  • the datarate, in case the LoRaMAC layer did not receive an acknowledgment
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
RTC_DATA_ATTR bool firstrun = true;
//__________Sensor
void sensor() {
pinMode(led, OUTPUT);
pinMode(sound_digital, INPUT);
//________DATA???
void downLinkAckHandle(McpsIndication_t *mcpsIndication)
printf("\n\tdownLinkAckHandle: ACK received\n");
printf("\n\t+REV DATA:%s,\n\tRXSIZE %d,\n\tPORT %d, RSSI: %d,\n\t SNR: %d,\n\t DATA_RATE:%d,\r\n",
        mcpsIndication->RxSlot ? "RXWIN2" : "RXWIN1", mcpsIndication->BufferSize, mcpsIndication->Port,
        mcpsIndication->Rssi, (int)mcpsIndication->Snr, (int)mcpsIndication->RxDoneDatarate);
void keyDown()
delay(10);
if(digitalRead(INT_PIN)==0 && IsLoRaMacNetworkJoined)
deviceState = DEVICE_STATE_SEND;
Mcu.begin();
if(loraWanClass==CLASS_C)
pinMode(INT_PIN,INPUT);
attachInterrupt(INT_PIN,keyDown,FALLING);
if(firstrun)
LoRaWAN.displayMcuInit();
firstrun = false;
void loop(){
//_____ Reading digital and analog values
int val_digital = digitalRead(sound_digital);
int val_analog = analogRead(sound_analog);
Serial.print("Digital Sound => ");
Serial.println(val_digital);
if (val_digital !=0)
digitalWrite (led, HIGH);
delay(500);
else
digitalWrite (led, LOW);
delay(500);
//_____ Check if the INT_PIN is HIGH and the device is joined to a LoRaWAN network
if (digitalRead(sound_digital) != 0 ) {
  digitalWrite(led, HIGH); // Turn on the LED to indicate activity
  Serial.print("Digital Signal: ");
  Serial.print(sound_digital);
//_____ Schedule next packet transmission with a randomized duty cycle
txDutyCycleTime = appTxDutyCycle + randr(-APP_TX_DUTYCYCLE_RND, APP_TX_DUTYCYCLE_RND);
//_____ Check if the device is in a sleep state
if (deviceState == DEVICE_STATE_SLEEP) {
//_____ Enable wake-up by external interrupt
  esp_sleep_enable_ext0_wakeup((gpio_num_t)INT_PIN, 0);
  prepareTxFrame(appPort);
  LoRaWAN.send();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
case DEVICE_STATE_JOIN:
  LoRaWAN.join();
case DEVICE_STATE_SEND:
  prepareTxFrame( appPort );
  LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
  if(loraWanClass==CLASS_A)
#ifdef WIRELESS_MINI_SHELL
    esp_deep_sleep_enable_gpio_wakeup(1<<INT_PIN,ESP_GPIO_WAKEUP_GPIO_LOW);
#else
    esp_sleep_enable_ext0_wakeup((gpio_num_t)INT_PIN,0);
  LoRaWAN.sleep(loraWanClass);
