Ive been searching all day and on every other post ive found on here there was no actual explanation for how to save the downlink data from the ESP32_LoRaWAN master library into a global variable so that it may be used elsewhere in the program. Ive seen people try to answer this question by pasting the OTAA_LED example with no follow on explanation to how it works. I see that you can make case statements in the void app((uint8_t data); function, but the problem is that you cant call the app() function in other parts of the sketch. Any solutions?
this is the example im referring to.
- HelTec Automation™ LoRaWAN 1.0.2 OTAA example use OTAA, CLASS A
- Function summary:
- You can use port 4 to control the LED light.
- If the issued value is 1(ASCII), the lamp will be lit.
- The release value is 2(ASCII) and the light will be turned off.
- use internal RTC(150KHz);
- Include stop mode and deep sleep mode;
- 15S data send cycle;
- Informations output via serial(115200);
- Only ESP32 + LoRa series boards can use this library, need a license
- to make the code run(check you license here: http://www.heltec.cn/search/);
- You can change some definition in “Commissioning.h” and “LoRaMac-definitions.h”
- HelTec AutoMation, Chengdu, China.
- 成都惠利特自动化科技有限公司
- https://heltec.org
- support@heltec.cn
*this project also release in GitHub:
*https://github.com/HelTecAutomation/ESP32_LoRaWAN
#include <ESP32_LoRaWAN.h>
#include “Arduino.h”
/*license for Heltec ESP32 LoRaWan, quary your ChipID relevant license: http://resource.heltec.cn/search */
uint32_t license[4] = {0x4915A653,0xC69E42EE,0x0D9EA6D4,0xB5201468};
/* OTAA para*/
uint8_t DevEui[] = { 0x22, 0x32, 0x33, 0x00, 0x00, 0x88, 0x88, 0x02 };
uint8_t AppEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t AppKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x66, 0x01 };
/* ABP para*/
uint8_t NwkSKey[] = { 0x15, 0xb1, 0xd0, 0xef, 0xa4, 0x63, 0xdf, 0xbe, 0x3d, 0x11, 0x18, 0x1e, 0x1e, 0xc7, 0xda,0x85 };
uint8_t AppSKey[] = { 0xd7, 0x2c, 0x78, 0x75, 0x8c, 0xdc, 0xca, 0xbf, 0x55, 0xee, 0x4a, 0x77, 0x8d, 0x16, 0xef,0x67 };
uint32_t DevAddr = ( uint32_t )0x007e6ae1;
DeviceClass_t loraWanClass = CLASS_C;
/OTAA or ABP/
/ADR enable/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
/*LoraWan debug level, select in arduino IDE tools.
- None : print basic info.
- Freq : print Tx and Rx freq, DR info.
- Freq && DIO : print Tx and Rx freq, DR, DIO0 interrupt and DIO1 interrupt info.
- Freq && DIO && PW: print Tx and Rx freq, DR, DIO0 interrupt, DIO1 interrupt and MCU deepsleep info.
#define LEDPin 25 //LED light
void app(uint8_t data)
// lora_printf(“data:%d\r\n”,data);
switch(data)
case 49:
pinMode(LEDPin,OUTPUT);
digitalWrite(LEDPin, HIGH);
case 50:
digitalWrite(LEDPin, LOW);
case 51:
lora_printf("+REV DATA:%s,RXSIZE %d,PORT %d\r\n",mcpsIndication->RxSlot?“RXWIN2”:“RXWIN1”,mcpsIndication->BufferSize,mcpsIndication->Port);
lora_printf("+REV DATA:");
app(mcpsIndication->Buffer[0]);
for(uint8_t i=0;iBufferSize;i++)
lora_printf("%02X",mcpsIndication->Buffer[i]);
lora_printf("\r\n");
appDataSize = 4;//AppDataSize max value is 64
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
void setup()
while (!Serial);
SPI.begin(SCK,MISO,MOSI,SS);
Mcu.init(SS,RST_LoRa,DIO0,DIO1,license);
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send(loraWanClass);
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass,debugLevel);
