I look to connect both boards via RS-232. For the ESP32 there are 2 URTS not used so not a problem.
What about the AB02S-GPS? Any possibility/idea how to use RX2/TX2?
Would expect that RX1/TX1 is for the USB? What about RTS/CTS?
Thanks a lot. How to setup/select/deine the pins for rtx1/ctx1?
@jasonXu
My understanding is as follows:
To use UART_NUM_1 I have to keep via Vect the GPS powered down and cannot use it.
Is this correct or do I miss something?
Thanks for the clarification in advance.
Cannot redefine RX and TX pins, This has been fixed on the hardware.
hi,
it control by GPIO14.
Thank’s a lot for the confirmation.
