just want to ask - is there any known issues with Dragino PG1302 + ChirpStack and Heltec devices?
Im planning to order it for my network based on AB01/02 modules.
btw - what the difference between category “CubeCell” and “Lora Node” in this forum?
Most of the LoRa nodes are based on an ESP32, at least none of them is based on CubeCell.
None that I am immediately aware of, besides the fact that you can pretty much only use Heltec’s own LoRaWAN stack as CubeCell/ASR650x is so borked that other stacks mostly don’t work for a longer period than a handful of messages. And YMMV with Heltec’s LoRaWAN stack. Depending on the usecase it either works fine and all good, or you’re hopelessly debugging a closed binary.
