Reduce current consumption of Lora WiFi V3 node
I’ve just successfully made my ESP32 Lora WiFi V3 node connected to LoraWan Gateway HT-M01S (V2.0). The node wakes up every 1min to deliver dummy data and the every currrent is around 9mA. The sleep current is normal (=19uA). I notice that every wakeup cycle will occupy around 5s on time, no matter my setting of “appTxDutyCycle” (15s, 5s or 0.5s). There will also a long wakeup every 4 cycles, which will sustain for around 10seconds.
Previously, I used the same node to transmit non-LoraWan packets and the average current can be down to 3mA.
Below shows my LoraWan node code. Could you please advise any hint to improve the current consumption?
Thanks!!
#include “LoRaWan_APP.h”
#include <ArduinoJson.h> // JSON library
#define ADC_CTL 37
#define V_EXT 36
#define LED 35
#define BATT 1
#define SIZE 100
StaticJsonDocument<100> Jsondata; // Create a JSON document of 100 characters max
float temp_value,hum_value,battery_lvl;
int sun_value = 0;
byte status = 0;
char msg[SIZE];
/* OTAA para*/
uint8_t devEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x05, 0xAA, 0xB6 };
uint8_t appKey[] = { 0xB1, 0x2C, 0x03, 0x01, 0xEA, 0xCD, 0x3B, 0x7C, 0xF7, 0xA9, 0xB6, 0xA6, 0x8A, 0x15, 0xB9, 0xE8 };
/* ABP para*/
uint8_t nwkSKey[] = { 0xC1, 0xAE, 0x15, 0x9D, 0x98, 0x59, 0x0E, 0xD3, 0x68, 0x39, 0x51, 0x5A, 0xF1, 0x2F, 0x93, 0x81 };
uint8_t appSKey[] = { 0xC1, 0xAE, 0x15, 0x9D, 0x98, 0x59, 0x0E, 0xD3, 0x68, 0x39, 0x51, 0x5A, 0xF1, 0x2F, 0x93, 0x81 };
DeviceClass_t loraWanClass = CLASS_A; //Class A
uint32_t appTxDutyCycle = 100;
/OTAA or ABP/
bool overTheAirActivation = true; //OTAA selected
/ADR enable/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port /
uint8_t appPort = 2;
  • Number of trials to transmit the frame, if the LoRaMAC layer did not
  • receive an acknowledgment. The MAC performs a datarate adaptation,
  • according to the LoRaWAN Specification V1.0.2, chapter 18.4, according
  • to the following table:
  • Transmission nb | Data Rate
  • 1 (first) | DR
  • 2 | DR
  • 3 | max(DR-1,0)
  • 4 | max(DR-1,0)
  • 5 | max(DR-2,0)
  • 6 | max(DR-2,0)
  • 7 | max(DR-3,0)
  • 8 | max(DR-3,0)
  • Note, that if NbTrials is set to 1 or 2, the MAC will not decrease
  • the datarate, in case the LoRaMAC layer did not receive an acknowledgment
appDataSize = strlen(msg);
for (int j = 0; j<appDataSize; j++){
appData[j] = msg[j];
//if true, next uplink will add MOTE_MAC_DEVICE_TIME_REQ
void create_data(){
temp_value = random(15,40);
hum_value = random(40,80);
battery_lvl =0;
digitalWrite(ADC_CTL,LOW); //Enable battery level resistor network
for (int i = 0; i<3; i++){
delay(50); //delay to get stable voltage
battery_lvl += float(analogRead(BATT))/40963.3/0.2041.06; //Adjustment for unit
battery_lvl = battery_lvl/3;
digitalWrite(ADC_CTL,HIGH); //Disable battery level resistor network
sun_value = random(30,100);
status = int(random(0, 2));
//Create JSON message
Jsondata[“Temp”] = temp_value; //temp_value read from DHT11
Jsondata[“Hum”] = hum_value; //humidity value read from DHT11
Jsondata[“Batt”] = battery_lvl; //battery_lvl read by “analogRead(xx)/4096*3.3”
Jsondata[“Sun”] = sun_value; //sunshine level ready by “analogRead(xx)/4096 * 100” in %
if (status ==0) Jsondata[“Status”] = “Discharging”;
else Jsondata[“Status”] = “Charging”;
//Packing the JSON message into msg
serializeJson(Jsondata, msg);
Serial.println(msg);
Serial.println(strlen(msg));
pinMode(LED,OUTPUT);
pinMode(ADC_CTL, OUTPUT);
Mcu.begin();
create_data();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
digitalWrite(LED, HIGH); //turn on LED
Serial.println(“Sending”);
prepareTxFrame(appPort);
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
//txDutyCycleTime = appTxDutyCycle + randr( -APP_TX_DUTYCYCLE_RND, APP_TX_DUTYCYCLE_RND );
txDutyCycleTime = 60000;
digitalWrite(LED, LOW); //turn off LED
Serial.println(“Going to Sleep”);
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass);
It looks like your code is configured to wait for an ACK after sending a message.
Since isTxConfirmed is true, the device will wait 5 seconds for a response.
Change the value to false and see if your 5 second delay goes away.
Sopwith
Thanks for your advice!
I’ve tried but only find that the big long pulse every 4 cycles now vanish. Every on-time is still up to 5seconds.
Could you please post your code on github or similar including the header files.
My compile wants the #include <ArduinoJson.h> // JSON library and I have downloaded a few similar named files but none seem to work
Hi smbunn,
Below is the shared link containing the code and the zip library:
LoRaWan-test
Thanks!!
Awesome, all working now.
