i am trying to receive plain LoRa packets from a soil moisture sensor.
I minimized the pingpong sketch to just receive the packets to this:
/* Heltec Automation Ping Pong communication test example
- Function:
- Ping Pong communication in two CubeCell device.
- Description:
- Only hardware layer communicate, no LoRaWAN protocol support;
- Download the same code into two CubeCell devices, then they will begin Ping Pong test each other;
- This example is for CubeCell hardware basic test.
- HelTec AutoMation, Chengdu, China
- 成都惠利特自动化科技有限公司
- www.heltec.org
- this project also realess in GitHub:
- https://github.com/HelTecAutomation/ASR650x-Arduino
#include “LoRaWan_APP.h”
#include “Arduino.h”
- RGB red means sending;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
#define TX_OUTPUT_POWER 5 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
#define LORA_SPREADING_FACTOR 9 // [SF7…SF12]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
typedef enum
LOWPOWER,
RX,
TX
}States_t;
int16_t txNumber;
States_t state;
bool sleepMode = false;
int16_t Rssi,rxSize;
txNumber=0;
Rssi=0;
Radio.Init( &RadioEvents );
state=RX;
Serial.print("State: ");
Serial.println(state);
switch(state)
case TX:
Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
case RX:
Serial.println(“into RX mode”);
Radio.Rx( 0 );
state=LOWPOWER;
case LOWPOWER:
lowPowerHandler();
Radio.IrqProcess( );
Rssi=rssi;
rxSize=size;
rxpacket[size]=’\0’;
turnOnRGB(COLOR_RECEIVED,0);
Radio.Sleep( );
Serial.printf("\r\nreceived packet \"%s\" with Rssi %d , length %d\r\n",rxpacket,Rssi,rxSize);
Serial.println("wait to send next packet");
state=RX;
It works fine and i get the packages:
13:46:32.334 -> into RX mode
13:47:27.063 ->
13:47:27.063 -> received packet “ID010132 REPLY : SOIL INEDX:0 H:43.72 T:23.85 ADC:877 BAT:892” with Rssi -31 , length 61
13:47:27.100 -> wait to send next packet
13:47:27.100 -> State: 1
13:47:27.100 -> into RX mode
But now comes the part which i don’t understand.
When i comment out this line like this it doesn’t work anymore:
case TX:
// Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
What kind of magic is this? The TX state should never been reached?
Greetings
Olaf
