Really big data loss
Hello, I have really big dataloss when transmitting data over lora. I use Heltec Wireless stick (V2) and HT-M00 gateway and most of my uplinks doesn’t get to the lora server (loriot) even not to the gateway (the led doesn’t blink and the tx and rx counters stay the same). This is weird, because join requests work perfectly and device joins everytime in 1-3 attempts. Do you know where this problem could lie on? I use modified uplinkDataHandle example.
#include "LoRaWan_APP.h"
/* OTAA para*/
uint8_t devEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t appKey[] = {  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
/* ABP para*/
uint32_t devAddr =  ( uint32_t )0x007e6ae1;
DeviceClass_t  loraWanClass = CLASS_C;
/*the application data transmission duty cycle.  value in [ms].*/
uint32_t appTxDutyCycle = 60000;
/*OTAA or ABP*/
/*ADR enable*/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first)       | DR
* 2               | DR
* 3               | max(DR-1,0)
* 4               | max(DR-1,0)
* 5               | max(DR-2,0)
* 6               | max(DR-2,0)
* 7               | max(DR-3,0)
* 8               | max(DR-3,0)
#define LEDPin 25  //LED light
void app(uint8_t data)
    // lora_printf("data:%d\r\n",data);
   switch(data)
    case 49:
      pinMode(LEDPin,OUTPUT);
      digitalWrite(LEDPin, HIGH);
    case 50:
      digitalWrite(LEDPin, LOW);
    case 51:
    Serial.println("Preparint TX frame!");
    appDataSize = 4;
    appData[0] = 0x00;
    appData[1] = 0x01;
    appData[2] = 0x02;
    appData[3] = 0x03;
//downlink data handle function example
  Serial.println("Received downlink");
  Serial.printf("+REV DATA:%s,RXSIZE %d,PORT %d\r\n",mcpsIndication->RxSlot?"RXWIN2":"RXWIN1",mcpsIndication->BufferSize,mcpsIndication->Port);
  Serial.print("+REV DATA:");
  app(mcpsIndication->Buffer[0]);
  for(uint8_t i=0;i<mcpsIndication->BufferSize;i++)
  Serial.println();
  uint32_t color=mcpsIndication->Buffer[0]<<16|mcpsIndication->Buffer[1]<<8|mcpsIndication->Buffer[2];
#if(LoraWan_RGB==1)
  turnOnRGB(color,5000);
  turnOffRGB();
  while (!Serial);
  Mcu.begin();
  switch( deviceState )
    case DEVICE_STATE_INIT:
      Serial.println("INIT STATE");
#if(LORAWAN_DEVEUI_AUTO)
    case DEVICE_STATE_JOIN:
      Serial.println("JOIN STATE");
      LoRaWAN.join();
    case DEVICE_STATE_SEND:
      Serial.println("SEND STATE");
      prepareTxFrame( appPort );
      LoRaWAN.send();
    case DEVICE_STATE_CYCLE:
      Serial.println("CYCLE STATE");
    case DEVICE_STATE_SLEEP:
      LoRaWAN.sleep(loraWanClass);
Here is my code with changed secrets.
Thanks in advance if somebody helps me with this problem.
HT-M00 is a dual-channel gateway, and your node is set with 8 channels.
How do I set it to work with only two channels? I suppose it has to do something with the channel mask?
