Question about Vext in the Code
Hi @jasonXu ,
Could you explain me a little bit what this line of code does pinMode(Vext,OUTPUT) ?
What is Vext? I can get my hear around it and I have seen it in almost every single example.
Thanks for your help.
Kind regards,
Hi, if you search for a pinout diagram, you will find a pin called “ve” or “vext”.
It’s a pin that deliver 3.3V and it’s anable via pinMode(Vext,OUTPUT) and the command Vext HIGH or LOW.
What are the board you use ?
Alex
Hi @AlexFR,
Thanks for your quick reply. I have seen this on the pinout : VEXT : External power supply (3.3V),
control the switch of VEXT through GPIO(LOW-ON,HIGH-OFF)
I am asking that because I don’t need to output 3.3V to power any device but I take out from my code, it doesn’t work. (example BME280) Any ideas why? if the purpose is just to give 3.3V, i don’t get it.
Take care.
I’have a success running AB01 board with a BME breakout.
Wiring: SDA-SCL from the BME to the CubeCell board. GND to GND and VIN from the breakout to Ve or Vext Pin of the CubeCell board.
On the code I use the with the #include <Seeed_BME280.h> library
and for example
// This enables the output to power the sensor
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
delay(500);
if(!bme280.init()){
if(ENABLE_SERIAL){
Serial.println(“Device error!”);
// This delay is required to allow the sensor time to init
delay(500);
temperature = bme280.getTemperature() * 100;
humidity = bme280.getHumidity();
pressure = bme280.getPressure();
Wire.end();
// Turn the power to the sensor off again
digitalWrite(Vext, HIGH);
The advantage of the Vext is to power a sensor only on demand with digitalWrite(Vext,LOW)
