I would like to use a Heltec Cube Cell Board Plus PIN configured as analog PWM.
It all works very well until it goes to sleep. When the board wakes up from sleep, the PWM pin doesn’t works. Any idea?
Below is the slightly modified basic code.
#include “LoRaWan_APP.h”
#include “Arduino.h”
#define pinBOOST PWM2
- set LoraWan_RGB to Active,the RGB active in loraWan
- RGB red means sending;
- RGB purple means joined done;
- RGB blue means RxWindow1;
- RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t appKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x66, 0x01 };
/* ABP para*/
/OTAA or ABP/
/ADR enable/
/* Application port /
uint8_t appPort = 2;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
setPWM_Frequency(PWM_CLK_FREQ_16M);
setPWM_ComparePeriod(0x100);
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
Serial.println(“PWM started”);
analogWrite(pinBOOST,64); // set duty cycle
delay(5000);
Serial.println(“PWM Finished”);
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
