Hello everyone, I am working with the custom examples of heltec esp32 Dev-Boards, Led_control_S and Led_control_R. without altering them, on my lora 32 v3 wifi plates. According to the serial monitor, everything is correct, but the LED does not light up when receiving the Open Led command. I have changed the output from GPIO 35, to GPIO 7, to 47,… what could it be? Thank you
Problems with heltec esp32 Dev-Boards, Led_control_S and Led_control_R
You might need to provide more information—I can’t see any sketches named Led_control_S or Led_control_R in the Arduino IDE examples for the WiFi LoRa 32 V3 board…
I sent you a screenshot and the original codes.
Send a lora signal to control the LED light switch of another board.
Pull the 12th pin high to turn on the LED light.
Pull pin 13 high to turn off the LED light.
by Aaron.Lee from HelTec AutoMation, ChengDu, China
成都惠利特自动化科技有限公司
this project also realess in GitHub:
https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series
#include “LoRaWan_APP.h”
#include “Arduino.h”
#define TX_OUTPUT_POWER 5 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
double txNumber;
bool lora_idle=true;
void OnTxDone( void );
void OnTxTimeout( void );
int counter = 0;
#define Open_LED 12
#define Close_LED 13
//WIFI Kit series V1 not support Vext control
Mcu.begin();
txNumber=0;
Radio.Init( &RadioEvents );
pinMode(Open_LED,INPUT);
digitalWrite(Open_LED,LOW);
pinMode(Close_LED,INPUT);
digitalWrite(Close_LED,LOW);
// LoRa.setTxPower(14,RF_PACONFIG_PASELECT_PABOOST);
if(digitalRead(Open_LED)){
Serial.print("Sending packet: OpenLED\r\n");
// send packet
if(lora_idle == true)
txNumber += 0.01;
sprintf(txpacket,"OpenLED %0.2f",txNumber); //start a package
lora_idle = false;
Radio.IrqProcess( );
if(digitalRead(Close_LED)){
Serial.print("Sending packet: CloseLED\r\n");
// send packet
txNumber += 0.01;
sprintf(txpacket,"CloseLED %0.2f",txNumber); //start a package
lora_idle = false;
Serial.println(“TX done…”);
lora_idle = true;
Radio.Sleep( );
Serial.println("TX Timeout......");
lora_idle = true;
Receive the lora signal to control the on and off of the LED.
成都惠利特自动化科技有限公司
#include “string.h”
#include “stdio.h”
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
int16_t txNumber;
int16_t rssi,rxSize;
bool lora_idle = true;
#define LED 35
char Readback[50];
Mcu.begin();
txNumber=0;
rssi=0;
pinMode(LED,OUTPUT);
digitalWrite(LED,LOW);
// try to parse packet
if(lora_idle)
lora_idle = false;
Radio.Rx(0);
Radio.IrqProcess();
rssi=rssi;
rxSize=size;
rxpacket[size]='\0';
Radio.Sleep( );
Serial.printf("\r\nreceived packet \"%s\" with rssi %d , length %d\r\n",rxpacket,rssi,rxSize);
lora_idle = true;
if(strncmp(rxpacket, “OpenLED”, strlen(rxpacket)) == 0) {
digitalWrite(LED, HIGH);
else if(strncmp(rxpacket, “CloseLED”, strlen(rxpacket)) == 0) {
digitalWrite(LED, LOW);
Yeah, OK, you’re running a later software revision than I am (and I’m not keen to change anything in my set-up at the moment because everything is working and I have other things to do). But there’s nothing in there that jumps out as being obviously problematic.
All I could suggest is inserting some extra print statements in there to verify that the condition statements that turn the LED ON and OFF are actually executed. Maybe also check that the LED turns ON and OFF with a ‘local’ sketch that doesn’t depend on the message being sent between the two modules. If that all checks out, then maybe the problem is in the way the ‘message’ is constructed or interpreted.
I use a more formal packet structure in my LoRa applications but I have no trouble sending various instructions, to perform a range of tasks, between LoRa nodes.
