At the moment I try to send packets between one Heltec WIFI LoRa V2 and another by reading the serial-line and sending the input via LoRa.
Small packtes (like 30 bytes) work everytime, but as bigger the packet gets the packet won’r be received everytime or even never.
So I write a little sendig loop, where my sender sends at every iteration a packet, which gets everytime 10 byte bigger and surprisingly every packet was received by the sender (I tried that until 500 bytes).
After that I wanted to send a 80 byte serial input message and this did not work. Do you know whats the problem with that?
// reader
// ... LoRa.begin(); ....
LoRa.onReceive(onReceive);
// ... LoRa.receive(); ...
void onReceive(int packetSize) { // uses the interrupt pin on the dio0
String packet = "";
packSize = String(packetSize,DEC);
for (int i = 0; i < packetSize; i++) {
packet += (char) LoRa.read();
Serial.println(packet);
delay(5);
// writer
boolean sendPacket (String packet) {
Serial.println("Send begin");
LoRa.beginPacket(false); // true: optional implicit mode (--> Set everything on both sides?!)
LoRa.print(packet); // also LoRa.write(byte(, length));
LoRa.endPacket(false); // true: async mode: doas not wair until transmission is completed
delay(250);
// put the radio into receive mode
LoRa.receive(); // set redio back in receive mode
delay(750);
Serial.println("Send end");
return true; // will be changed
void loop(){
while(Serial.available() > 0 ){
delay(2); //delay to allow byte to arrive in input buffer
String text = Serial.readString();
digitalWrite(LED, HIGH); // turn the LED on (HIGH is the voltage level)
boolean packetSent = false;
while (!packetSent) {
packetSent = sendPacket(text);
if (packetSent) {
Serial.print("Packet has been sent: ");
Serial.println(text);
} else {
Serial.print("Retry sending packet: ");
digitalWrite(LED, LOW); // turn the LED off (HIGH is the voltage level)
