Problem in transmission on TTN and Helium network with CubeCell Dev-Board HTCC-AB01
Hi everyone, I have a problem with the ubeCell Dev-Board HTCC-AB01, I cannot transmit data on the TTN and on the Helium network, I don’t understand where I am wrong, I am attaching the code:
The netmode used is OTAA.
#include <LoRaWan_APP.h>
#include <Arduino.h>
#include <Seeed_BME280.h>
#include <Wire.h>
/* OTAA para TTN*/
uint8_t devEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t appKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88 };
/* ABP para TTN*/
uint8_t nwkSKey[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t appSKey[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint32_t devAddr = ( uint32_t )0x00000000;
/* OTAA para HELIUM*/
//uint8_t devEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
//uint8_t appEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
//uint8_t appKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88 };
/* ABP para HELIUM*/
//uint8_t nwkSKey[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
//uint8_t appSKey[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
//uint32_t devAddr = ( uint32_t )0x00000000;
bool ENABLE_SERIAL = true; // enable serial debug output here if required
uint32_t appTxDutyCycle = 120000; // the frequency of readings, in milliseconds(set 300s)
uint8_t appPort = 2;
int temperature, humidity, batteryVoltage, batteryLevel;
long pressure;
BME280 bme280;
// This enables the output to power the sensor
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
delay(500);
if(!bme280.init()){
if(ENABLE_SERIAL){
Serial.println(“Device error!”);
// This delay is required to allow the sensor time to init
delay(500);
temperature = bme280.getTemperature() * 100;
humidity = bme280.getHumidity();
pressure = bme280.getPressure();
Wire.end();
// Turn the power to the sensor off again
digitalWrite(Vext, HIGH);
batteryVoltage = getBatteryVoltage();
batteryLevel = (BoardGetBatteryLevel() / 254) * 100;
appDataSize = 12;
appData[0] = highByte(temperature);
appData[1] = lowByte(temperature);
appData[2] = highByte(humidity);
appData[3] = lowByte(humidity);
appData[4] = (byte) ((pressure & 0xFF000000) >> 24 );
appData[5] = (byte) ((pressure & 0x00FF0000) >> 16 );
appData[6] = (byte) ((pressure & 0x0000FF00) >> 8 );
appData[7] = (byte) ((pressure & 0X000000FF) );
appData[8] = highByte(batteryVoltage);
appData[9] = lowByte(batteryVoltage);
appData[10] = highByte(batteryLevel);
appData[11] = lowByte(batteryLevel);
if(ENABLE_SERIAL){
Serial.print("Temperature: ");
Serial.print(temperature / 100);
Serial.print(“C, Humidity: “);
Serial.print(humidity);
Serial.print(”%, Pressure: “);
Serial.print(pressure / 100);
Serial.print(” mbar, Battery Voltage: “);
Serial.print(batteryVoltage);
Serial.print(” mV, Battery Level: “);
Serial.print(batteryLevel);
Serial.println(” %”);
void setup()
boardInitMcu();
if(ENABLE_SERIAL){
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
deviceState = DEVICE_STATE_SEND;
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
In the TTN console I don’t see any join message while in Helium I only see many Join request and Join Accept messages. In the serial monitor I see that it stops in the join phase giving me an error after a few minutes. I ask you for help, I am quite frustrated. Thank you
Can you show the error message?
try changing the appKey[]
