Powered with 12V, want LED off and deep_sleep power saving
I already read, that you can only turn off the two LEDs when using battery power, is that right?
Another thing I read, that power consumption in deep sleep is much lower when using battery power than e.g. USB-C port. Is this also true?
I’ve a 12V power source (battery) and now want to power the Wireless tracker. I want to be safe as most power as possible, so I want to turn off the LED and use most of deep_sleep.
What to do? Get a DC/DC 12V to 3,7V and connect to battery input?
Would be much easier to use USB-C and configure LED and deep_sleep via SW, but is this possible?
Thank you for any help!
Maybe Heltec Team can help with this? Thanks!
