I have made a simmilar post yesterday but have noticed something bigger today. Even the normal ping pong example without making it faster gets stuck in rx mode within a minute? Just opened ping pong example changed the frequency and ran it. Both boards are in rx mode rather than one in rx mode and one in tx mode. Please help i need this example to work since i have made a more complicated program based on this and it neither works.
Board heltec esp32 lora v2. Frequency 433-510.
then they both just stopped transmitting because both boards are expecting a message? Thats just my assumption.
#include "LoRaWan_APP.h"
#include "Arduino.h"
#define RF_FREQUENCY
433000000 // Hz
#define TX_OUTPUT_POWER
5 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
void OnTxDone( void );
void OnTxTimeout( void );
typedef enum
LOWPOWER,
STATE_RX,
STATE_TX
}States_t;
int16_t txNumber;
States_t state;
bool sleepMode = false;
int16_t Rssi,rxSize;
Mcu.begin();
txNumber=0;
Rssi=0;
Radio.Init( &RadioEvents );
state=STATE_TX;
switch(state)
case STATE_TX:
txNumber++;
sprintf(txpacket,"hello %d, Rssi : %d",txNumber,Rssi);
Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
state=LOWPOWER;
case STATE_RX:
Radio.Rx( 0 );
state=LOWPOWER;
case LOWPOWER:
Radio.IrqProcess( );
Serial.print("TX done......");
state=STATE_RX;
Radio.Sleep( );
Serial.print("TX Timeout......");
state=STATE_TX;
Rssi=rssi;
rxSize=size;
rxpacket[size]='\0';
Radio.Sleep( );
Serial.printf("\r\nreceived packet \"%s\" with Rssi %d , length %d\r\n",rxpacket,Rssi,rxSize);
Serial.println("wait to send next packet");
state=STATE_TX;
