in this code what is the pin out for CubeCell 1 / 2AA Node
I have tried with pins 36 and 37 -39 and 40 for scl and sda and the sensor does not send information
#include <LoRaWan_APP.h>
#include <Arduino.h>
#include <Seeed_BME280.h>
#include <Wire.h>
/* OTAA para*/
uint8_t devEui[] = { 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX }; //#Insert you Development EUI here as indivudal bytes replacing each XX pair
uint8_t appEui[] = { 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX }; //#Insert you Application EUI here as indivudal bytes replacing each XX pair
uint8_t appKey[] = { 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX }; //#Insert you Application Key here as indivudal bytes replacing each XX pair
bool ENABLE_SERIAL = true; // enable serial debug output here if required
uint32_t appTxDutyCycle = 100000; // the frequency of readings, in milliseconds(set 100s)
uint8_t appPort = 2;
int temperature, humidity, batteryVoltage, batteryLevel;
long pressure;
BME280 bme280;
// This enables the output to power the sensor
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
delay(500);
if(!bme280.init()){
if(ENABLE_SERIAL){
Serial.println(“Device error!”);
// This delay is required to allow the sensor time to init
delay(500);
temperature = bme280.getTemperature() * 100;
humidity = bme280.getHumidity();
pressure = bme280.getPressure();
Wire.end();
// Turn the power to the sensor off again
digitalWrite(Vext, HIGH);
batteryVoltage = getBatteryVoltage();
batteryLevel = (BoardGetBatteryLevel() / 254) * 100;
appDataSize = 12;
appData[0] = highByte(temperature);
appData[1] = lowByte(temperature);
appData[2] = highByte(humidity);
appData[3] = lowByte(humidity);
appData[4] = (byte) ((pressure & 0xFF000000) >> 24 );
appData[5] = (byte) ((pressure & 0x00FF0000) >> 16 );
appData[6] = (byte) ((pressure & 0x0000FF00) >> 8 );
appData[7] = (byte) ((pressure & 0X000000FF) );
appData[8] = highByte(batteryVoltage);
appData[9] = lowByte(batteryVoltage);
appData[10] = highByte(batteryLevel);
appData[11] = lowByte(batteryLevel);
if(ENABLE_SERIAL){
Serial.print("Temperature: ");
Serial.print(temperature / 100);
Serial.print(“C, Humidity: “);
Serial.print(humidity);
Serial.print(”%, Pressure: “);
Serial.print(pressure / 100);
Serial.print(” mbar, Battery Voltage: “);
Serial.print(batteryVoltage);
Serial.print(” mV, Battery Level: “);
Serial.print(batteryLevel);
Serial.println(” %”);
void setup()
boardInitMcu();
if(ENABLE_SERIAL){
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
