Hi everyone,
I recently purchased several Heltec boards: Heltec LoRa WiFi V3 , Heltec Wireless Stick V3 , and Heltec Wireless Tracker . I’m trying to use the LoRaWAN LMIC library 5.0,1 with these boards, but I’m struggling to figure out the correct pin mapping for the library.
I’m using this library because when I attempt to use Heltec’s own LoRaWAN library, I can’t get the boards to properly send messages to the LoRaWAN Network Server after entering deep sleep mode.
For heltec wireless stick V3
const lmic_pinmap lmic_pins = {
.nss = 6,
.rxtx = LMIC_UNUSED_PIN,
.rst = 5,
.dio = {2, 3, 4},
However, I’m not sure if this is correct for the Heltec boards I’m using.
Does anyone have experience setting up LMIC with these Heltec boards or know the correct pin mappings?
Additionally, if anyone has an example of using LoRaWAN with deep sleep mode on these boards, I would greatly appreciate it.
Thanks in advance for your help!
