OLED How to display QR code
Can I display QR code in the OLED dysplay?
For example this library:
@jasonXu friend do you think is possible generate QR code with devEUI and show over OLED ?
Yes, I think this can be achieved.
But you need the High pixel OLED screen to display the QR code.
The included screen will not meet the requirements to show QR code ?
yes, the AB02’s screen is Too narrow.
QR code generation is possible on Heltec ESP32 kit that comes with OLED. However due to the display size limitation, the maximum number of characters that it can convert to a QR code is also much less. The tests I did so far could only code less than 15 characters. Here is the code that works. Courtesy: https://eugeniopace.org/qrcode/arduino/eink/2019/07/01/qrcode-on-arduino.html
Install this library: https://github.com/ricmoo/QRCode
#include "qrcode.h"
#include "heltec.h"
    Heltec.begin(true, false, true);
    Heltec.display->clear();
    // Create the QR code
    QRCode qrcode;
    const int qrcodeVersion = 3;
    const int pixelsPerSquare = 2;
    const int ecc_low = 0;
    uint8_t qrcodeData[qrcode_getBufferSize(qrcodeVersion)];
    qrcode_initText(&qrcode, qrcodeData, qrcodeVersion, ecc_low, "HELLO WORLD");
    for (uint8_t y = 0; y < qrcode.size; y++) {
        for (uint8_t x = 0; x < qrcode.size; x++) {
          //If pixel is on, we draw a ps x ps black square
          if (qrcode_getModule(&qrcode, x, y)) {
            for(int xi = x*pixelsPerSquare + 2; xi < x*pixelsPerSquare + pixelsPerSquare + 2; xi++){
              for(int yi= y*pixelsPerSquare + 2; yi < y*pixelsPerSquare + pixelsPerSquare + 2; yi++){
                Heltec.display->setPixel(xi, yi);
    Heltec.display->display();
