I recently received my boards from the Heltec Store and noticed that instead of de specified Air530Z chip, it has a chip with G12 on it.
I installed all the stuff in Arduino and tried a few example-sketches. But whatever I run, i do not get a GPS location fix. Not even if I stand outside under a clear sky.
Is it the chip? Is it the sketch? The combination?
Any help would be greatly appreciated.
Regards,
Guido
The Netherlands
I have the same problem. Using Heltec’s provided LoRaWAN GPS Sensor Example with 120s of GPS Fix timeout, I don’t get a fix, even with an additional external GPS antenna. I’ve tried both the Air503 and Air503Z versions of the libraries.
