Hi, I am new working with LoRaWAN, I am developing a project that I need to use this protocol. I bought the CubeCell HTCC-AB01 node from the 915 MHz Heltec brand. Since I’m new to this, I literally haven’t opened the box. I would like you to indicate where I can find a tutorial where they explain to me from scratch. I need to know what function each pin has, what pins should I connect, how should I connect them, how should I connect the HTCC-AB01 node to the gateway, how should I do the tests, how can I control a sensor remotely with the help of HTCC-AB01 node. The gateway I have is a UG87 Ursalink brand. Any information you can offer me will be very useful. Thank you.
New using CubeCell HTCC-AB01
Hi, there are some documents for CubeCell series, that will make sense to you:
- CubeCell quick start: https://heltec-automation-docs.readthedocs.io/en/latest/cubecell/quick_start.html
- CubeCell pin map and schematic diagram: https://resource.heltec.cn/download/CubeCell/HTCC-AB01
- Connect to a gateway and server: https://heltec-automation-docs.readthedocs.io/en/latest/cubecell/lorawan/index.html
