Need help about LoRa IQ INVERSION
I need to made cube cell broad to receive Request command in LoRa normal mode (inversion IQ is flase) and send data back in LoRa inversion IQ mode (inversion IQ= true) by change parameter in Radio.SetRxConfig and Radio.SetTxConfig like this
true, 0, 0, true, 3000 );
0, true, 0, 0, false, true );
But it receive and transmit data in LoRa normal mode. I don’t know do something wrong or have other way to set LoRa Rx and Tx work in different inversion mode.
Here is a LoRa normal mode receiver example:
And here is the key to success node-to-node communication:
https://heltec-automation-docs.readthedocs.io/en/latest/esp32/frequently_asked_questions.html#node-to-node-communication
