I have the HTCC-AB01 connected to an ultrasonic sensor HC-SR04 with pin GIO1 and GIO2. I can’t get the code to send over Lora to Heltec WiFi Kit 32 OLED. Would like the AB01 to transmit distance to the ESP32 then deep sleep for 10 minuets. It will be on running it on battery and solar panel. I would also like it to transmit battery voltage.
Need coding service
I think I am more stuck on the TX part. I have the sensor working but can’t send the value.
case TX:
sprintf(txPacket,"%s",“ADC_battery: “);
sprintf(txPacket+strlen(txPacket),”%d”,voltage);
turnOnRGB(COLOR_SEND,0);
Serial.printf("\r\nsending packet “%s” , length %d\r\n",txPacket, strlen(txPacket));
Radio.Send( (uint8_t *)txPacket, strlen(txPacket) );
state=LOWPOWER;
#include “LoRaWan_APP.h”
#include “Arduino.h”
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
#define LORA_SPREADING_FACTOR 8 // [SF7…SF12]
#define LORA_CODINGRATE 4 // [1: 4/5,
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
#define trigPin GPIO1
#define echoPin GPIO2
float duration;
float distance;
char txPacket[BUFFER_SIZE];
double txNumber;
void OnTxDone( void );
void OnTxTimeout( void );
typedef enum
LOWPOWER,
ReadVoltage,
TX
} States_t;
States_t state;
bool sleepMode = false;
int16_t rssi, rxSize;
uint16_t voltage;
boardInitMcu( );
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
voltage = 0;
rssi = 0;
Radio.Init( &RadioEvents );
state = ReadVoltage;
switch (state)
case TX:
state=LOWPOWER;
case LOWPOWER:
lowPowerHandler();
delay(100);
turnOffRGB();
delay(2000); //LowPower time
case ReadVoltage:
//Voltage
pinMode(VBAT_ADC_CTL, OUTPUT);
digitalWrite(VBAT_ADC_CTL, LOW);
voltage = analogRead(ADC) * 2;
pinMode(VBAT_ADC_CTL, INPUT);
//Ultrasonic
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin,
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
float distance = duration * 0.034 / 2;
Serial.println(distance);
state = TX;
Radio.IrqProcess();
Serial.println(“TX done!”);
turnOnRGB(0, 0);
Radio.Sleep( );
Serial.print(“TX Timeout…”);
sorry, Heltec WiFi Kit 32 OLED have not LoRa hardware.
WiFi LoRa 32 have LoRa hardware. https://heltec.org/project/wifi-lora-32/
Sorry I ment to the WiFi LoRa 32. I just need help with the TX part.
look at the lorawan example to sent some bytes:
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
I posted almost the same question, if you search for coding service.
I’m not using the battery monitor. Yhis code is working sending distance reading from cubecell to Heltec ESP32 OLED V2
Here is the code
/* Heltec Automation send communication test example
- Function:
- Send data from a CubeCell device over hardware
- this project also realess in GitHub:
- https://github.com/HelTecAutomation/ASR650x-Arduino
#include “Wire.h”
int duration;
float dist = 0;
#define trigPin GPIO3
#define echoPin GPIO5
#define timetillsleep 5000
#define timetillwakeup 7200000
//#define timetosleep 1000
//#define timetowake 7200000 2 HRS 20000 24 sec
static TimerEvent_t sleep;
static TimerEvent_t wakeUp;
uint8_t lowpower=1;
- RGB red means sending;
#ifndef LoraWan_RGB
#define TX_OUTPUT_POWER 22 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define BUFFER_SIZE 10 // Define the payload size here
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
// double txNumber;
int16_t rssi,rxSize;
//void DoubleToString( char *str, double double_num,unsigned int len);
void getDistance() {
pinMode(Vext, OUTPUT);
digitalWrite(Vext, HIGH);
Wire.begin();
digitalWrite(Vext, LOW);
delay(100);
dist = ((duration/2) / 29.1 * 0.39370);
Serial.print("Distance: ");
Serial.println(dist);
delay (1000);
Wire.end();
void onSleep()
Serial.printf(“Going into lowpower mode, %d ms later wake up.\r\n”,timetillwakeup);
lowpower=1;
//timetillwakeup ms later wake up;
TimerSetValue( &wakeUp, timetillwakeup );
TimerStart( &wakeUp );
void onWakeUp()
Serial.printf(“Woke up, %d ms later into lowpower mode.\r\n”,timetillsleep);
lowpower=0;
TimerStart( &sleep );
boardInitMcu( );
rssi=0;
Radio.Sleep( );
TimerInit( &sleep, onSleep );
onSleep();
// time_now = millis();
// while (millis() < time_now + 500) {
onWakeUp();
Radio.SetSyncWord(0x12); // 0x12 (private) or 0x34 (LoRaWan)
if(lowpower){
else {
getDistance();
char *str_temp;
String msgT = “”;
msgT = String(dist, 1);
memset(txpacket, 0, BUFFER_SIZE);
// converting strig to a char?
str_temp = (char*)(msgT).c_str();
sprintf(txpacket, “%s”, str_temp);
//Serial.printf("\r\nsending packet “%s” , length %d\r\n",txpacket, strlen(txpacket));
Serial.printf("\r\nsending packet “%s” , length %d\r\n", txpacket, strlen(txpacket));
