Here is a sketch, mix of examples.
Send data and sleep 20 Sec.
I accept suggestions.
#include "LoRaWan_APP.h"
#include "Arduino.h"
#define timetosleep 1000
#define timetowake 20000
static TimerEvent_t sleep;
static TimerEvent_t wakeup;
uint8_t lowpower=1;
* RGB red means sending;
* RGB blue means RxWindow1;
* RGB yellow means RxWindow2;
/*LoraWan Class*/
DeviceClass_t CLASS=LORAWAN_CLASS;
/*OTAA or ABP*/
bool OVER_THE_AIR_ACTIVATION = LORAWAN_NETMODE;
/*ADR enable*/
bool LORAWAN_ADR_ON = LORAWAN_ADR;
bool KeepNet = LORAWAN_Net_Reserve;
/*LoraWan REGION*/
LoRaMacRegion_t REGION = ACTIVE_REGION;
bool IsTxConfirmed = false;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
uint8_t ConfirmedNbTrials = 1;
/* Application port */
uint8_t AppPort = 2;
uint32_t APP_TX_DUTYCYCLE = 15000;
static void PrepareTxFrame( uint8_t port )
AppDataSize = 4;//AppDataSize max value is 64
AppData[0] = 0x00;
AppData[1] = 0x02;
AppData[2] = 0x01;
AppData[3] = 0x03;
BoardInitMcu();
#if(AT_SUPPORT)
Enable_AT();
DeviceState = DEVICE_STATE_INIT;
LoRaWAN.Ifskipjoin();
Serial.println( "[stup] INIT");
#if(AT_SUPPORT)
getDevParam();
Serial.println ("");
Serial.println("[pram] ***********************************");
printDevParam();
Serial.printf("[stup] LoRaWan Class%X start! \r\n",CLASS+10);
LoRaWAN.Init(CLASS,REGION);
Serial.println( "[stup] JOIN");
LoRaWAN.Join();
TimerInit( &sleep, OnSleep );
TimerInit( &wakeup, OnWakeup );
OnSleep();
if(lowpower)
//note that LowPower_Handler() run six times the mcu into lowpower mode;
LowPower_Handler();
void OnSleep()
Serial.printf("[lowp] lowpower mode %d ms\r\n",timetowake);
Serial.println("---------------------------zzzzzzzz----------------------------");
lowpower=1;
//timetosleep ms later wake up;
TimerSetValue( &wakeup, timetowake );
TimerStart( &wakeup );
void OnWakeup()
Serial.printf("[wkup] wake up, %d ms later into lowpower mode.\r\n",timetosleep);
uint32_t currentTime=TimerGetCurrentTime()/1000;
Serial.printf("[time] upTime: %d sec. \r\n",currentTime);
lowpower=0;
//timetosleep ms later into lowpower mode;
Serial.print( "[ttn ] ");//sending
PrepareTxFrame( AppPort );
LoRaWAN.Send();
Serial.println( "CYCLE");
TxDutyCycleTime = APP_TX_DUTYCYCLE + randr( 0, APP_TX_DUTYCYCLE_RND );
LoRaWAN.Cycle(TxDutyCycleTime);
Serial.println("[ttn ] SEND");
LoRaWAN.Sleep();
TimerSetValue( &sleep, timetosleep );
TimerStart( &sleep );
